Results 1 to 8 of 8
June 13th, 2013 12:15 AM #1
guys may idea ba kayo kung anong sira ng oto ko..
bigla nalang ayaw mamatay ng door lights kahit naka close lahat ng pintuan.
namamatay lang pag dinidiinan ko yung clutch or pag nagagalaw yung clutch..
isuzu ls 1994
- 54,216
June 13th, 2013 12:25 AM #2my guess is, there's probably a loose connection that your clutch is abutting on. from either side of the wall..
June 13th, 2013 12:29 AM #3
Am no electrical expert, but if sakin nangyari yan,
first thing to do is to be sure everything is connected to where it is supposed to be connected.
Id check the clutch pedal if may tinatamaan or nadadampiang wire sya sa ilalim if pinipress or ginagalaw, kasi i dont think may relation yung clutch sa pedal.
Tingin ko nga may loose connection lang and pag nagagalaw ay tumatama na yung contact and it works properly.
Pag may loose hanging wire, and hindi mo alam kung san dapat nakakabit, ipatignan mo nln sa electrician, baka mag short pa pag dinikit sa kung saan saan.
June 13th, 2013 12:37 AM #4
salamat mga sir!
bukas umaga ko na ipapatingin.. baka nga may natatamaan na loose connection, tinangal ko muna yung bulbs sa pinto para hindi kumain ng kuryente..
nakakaasiwa kasi habang nag ddrive kanina naka on yung ilaw. :|
June 13th, 2013 01:05 PM #5
stuck door switch lang pala nakuha sa second try.. pero mali yung unang diagnose nung rey electrical kinalas kalas pa yung wirings ko.. charge sa akin 500 reasonable ba?
June 13th, 2013 01:45 PM #7
naayos naman sir pero yung 500 para sa inadjust lang na door switch na stuck eh parang hindi reasonable...
500 yung na charge sa akin kasi kinalas yung wiring inabot ng mga isang oras din yung unang gawa pero hindi pala sa wiring eh switch lang.
June 13th, 2013 01:54 PM #8
sir, kung isang oras binaklas.... at naayos naman sa huli dahil door switch stuck lang, negotiate mo na lang tawaran mo ng 50% and negotiate with him from there.
Thanks, I checked them out pero walang Michelin Ang laki ng difference ng price sa Jiga....
Finding the Best Tire for You
