Yes, you can use an ammeter as a voltmeter. The best range to use (to use as a voltmeter) would be low-range ammeters (ex: ľAmp range) - I'll explain the reason later.
You can connect the ammeter the same way as a voltmeter, but with one tiny detail ... that is to insert a precision resistor in series to the meter. 'Di ko mai-drawing, so ganito lang:
(+) battery to (+) ammeter, (-) ammeter to resistor end, opposite resistor end to (-) battery. Actually you can insert the resistor on the other side of the meter, series naman siya.
Now, according to Ohm's law ...
voltage = current * resistance
V = I*R
Pick a fullscale voltage mark, say you want
16v to be the max reading of your ammeter. If your ammeter's dial range is
0-100 ľAmp, then you'll know what resistor to use ...
R = V/I
R = 16v / 100 ľA
R = 160kΩ
To know at what ľA mark the other voltage readings would be, use Ohm's law again. Like at 14volts, the ammeter reading would be ...
I = E/R
I = 14v / 160kΩ
I = 87.5ľA
And so on for the other voltage readings ...
Now if you're going to use a high-current ammeter, medyo mahihirapan kang maghanap ng high-wattage[SIZE=4][SIZE=2] precision resistor. But if you are to use a [SIZE=4][SIZE=2]ľ-ammeter
as a voltmeter and an ammeter, too, bitin naman yung range ng ammeter because of the large current involved. [/SIZE][/SIZE][/SIZE][/SIZE]
Ooops ... sumobra pagka-OT
[SIZE=4][SIZE=2][SIZE=4][SIZE=2]HTH[/SIZE]
