Results 1 to 6 of 6
    Sep 2006
    I finally found ung noise problem ng sa Engine bay... it was the alternator belt
    my car is a honda ESI
    Question:
    1.sobrang nipis na at natanggal na ung rubber sa mismong belt ngayon ko lang napansin parang nabiyak nung bumagyo at nainitan.. posible bang i-home service ang replacement ng belt or kailangan i-lift ung car?
    buti nagcheck ako kasi the last time i checked walang signs of damagae.. nagtaka ako nawala ung noise un pala natangal na ung rubber sa mismong alternator belt.
    2.anong brands po marerecommend nyo ung di masyado mahal na good quality and how much?
    3.any shops na malapit west avenue na malapit kasi parang mapuputol na talaga ung itsura ng belt parang plastic twine na...
    thanks in advance
    madali lang magpalit ng belt kung meron kang tools ... just in case burado na ang number nya, yung esi 95 ko dati gamit nyang alternator belt 4PK779 pero diko na matandaan yung brand (mitsuboshi yata)
    pwede rin have it remove muna by the mechanic and take it as a sample sa pagbili mo ng bago.. mitsuboshi, gates at dayco are good brands
    alam ko depende sa ayos nung belt sa crankshaft pulley.. baka may kelangan pang remove na other belts bago sya maalis at maikabit yung bagong belt, CMIIW though or better yet, pag may budget ka palitan mo na lang all of the belts, hehe
    Jul 2006
    Magtawag-tawag ka marami naman home mechanic. Just tell them what your car is model and year papalitan mo na lang lahat para minsanan na lang kaysa sa patawag ka ulit pag naputol ang iba. Dagdagan mo na lang bayad mo sa kanya para pamasahe at conveniece na rin.
    Sep 2006
    magkano kaya ung belt? any estimate?baka nga papalit ko na run ung sa compressor kasi natanggal din sya nung may natanggal na part belt ng alternator belt... kailangan pa bang i lift yan?
    Yung belt between Php350-500 ata siya. You don't really need a lift to replace the belts. Just turn the wheel to one side and pry the fender liner open.
HELP! Alternator Question
