Results 1 to 12 of 12
    May 2010
    Bought one at AutoIntensity Banawe 850 php Raizin Black.
    parang mura siya compare sa ibang shops. Paano ba malalaman kung orig or imitation?
    Ok ba 'to?
    yan ba yung kinakabit lang sa positive and negative terminal bateri tapos mag iiba na feeling mo sa kotse mo??
    May 2010
    Yes sir,
    BTW here is my Volt Stabilizer
    https://fbcdn-sphotos-a.akamaihd.net...13744208_n.jpg
    I hope Orig siya.
    "Notice of Fake RAIZIN" | PIVOT
    How to tell if it's fake or not.
    Upon googling Raizin volt stabilizer, napunta ako sa HCCP forums. A member bought his at Speedlab for 7k daw.
    Sep 2004
    fyi: speedlab sells only class a as per what they have told me before.
    May 2010
    Oh Sh*t, I hope its not fake.
    What happens if I Installed a fake one? Anong possible damage niyang gagawin?
    sana big 3 upgrade na lang. imho , that thing is useless.
    Quote Originally Posted by mikomac View Post
    Kung read out lang naman ng volt ang habol, walang problem kahit fake. Baka sa durability lang magkatalo.
    Sep 2004
    Quote Originally Posted by [archie] View Post
    i agree. no difference on performance i guess.............
    May 2010
    I'm not really into the performance side, but I have installed Sound systems, which I think will really be a big help on the battery and alternator. and I also heard, the battery will have a longer life though I'm still not sure if I will remove the said Volt Stabilizer or it will stay installed.
    BTW I just called the shop where I bought it. He honestly claimed it as a "Copy" which I remembered that I didn't ask first if its Legit or not. Silly me.
    Apr 2010
    I also have a sound system installed in my ride. At night with all the lights on plus the air conditioning with my system going full blast I get a reading of 12.0-12.25 when at idle. Might get the "BIG 3" sometime because of this.
    From what I hear, the Big 3 upgrade is always recommended for those with loud systems installed. This is the first thing you should try to do before trying to upgrade your battery and alternator. I don't hear much about how volt stabilizers help with sound systems. You might want to try this upgrade if you're not too sure about the stabilizer.
    Jul 2010
    Filter capacitors lang component ng voltage stabilzer. So, kung may loose ground connection ay maging 12V lang +Battery mo. Yun nga lang medyo eliminated mga noise or fluctuation dahil sa poor grounding.
    Kung ang Voltage Stabilizer ay worth 7K ay dun na ko sa Grounding Kit na 1k lang. Eliminated yun voltage drop therefore solve na yun noise or voltage fluctuation problem. Since nabawasan ang voltage drop ay maging +13.5V uli ang Alternator at +Bat mo. Liliwanag headlamp mo, Gaganda tunog ng car stereo, di mag blink mga gauges mo. Balik uli yun lakas ng voltage sa Ignition System mo na katulad ng bagong kotse.
    Ano pipiliin mo ngayun? 7k stabilized voltage or 1K Grounding KIt stabilized din ang voltage na mas maraming benefit as I mentioned above.
Volt Stabilizers.
