Results 1 to 13 of 13
    Jun 2011
    GO to mardenrey balic balic manila near blumentrit.... 140 amperes nila nasa 5.5k lang including installation....
    Jan 2013
    Pero kakayanin ba ng charging ng sasakyan namin if ung 25 AMPs na alternator namin ay lagyan ng Car Audio as I mentioned above?
    No prob naman sa charging un. and ung Motolite na Enduro ay tumatagal ng almost 2 years at 1 start din ung sasakyan mga sir
    Jul 2006
    Quote Originally Posted by Benjamin Nacis View Post
    No, hindi kakayanin ng present alternator niyo ang current requirements ng "sound-set-up" niyo. At the very least, upgrade your alternator into a 55 amp unit. Its much better to have an alternator na medyo malaki sa current requirements ng electrical system niyo than an under capacity one.
    Jan 2013
    Ahh thanks po sa reply. How much naman po magagastos if Ung current alt namin is ipataas ung charging capacity nya? Is it much cheaper kung bibili na lang ng bagong alt na 60 or 140 amp tulad ng sabi ni glenn or ipataas na lang ung charging capacity nitong current amp namin?
    Jul 2006
    I dont know how much magagastos ninyo, but I think its not that expensive. I suggest you replace the whole alternator with a bigger capacity one.
    Jan 2013
    Hindi ba masusunog ung mga other wiring ko gaya ng sa lights, electric fan or other electrical wirings if tinaasan ko ung AMP charging ko if fully charged na sya for example to 140 AMPS?. I mean na if nasa 0 Amps na ung Amp Meter ko and tumatakbo na ako ng malayo diba ung alt na lang nagsusuply ng other electricals sa sasakyan habang umaandar and ung battery is full charge na nun. san mapupunta ung excess na electrical if tinaasan ko kunwari ng 140 AMPs ung charging system nya?
    Oct 2011
    nakikita kong problema ay ung baterya baka mabilis masira if you increase the ampere capacity of your alternator. maganda sa baterya dahan2x pag charge.
    Jun 2011
    IMO same 12volts pa din ang output ng alternator mo at battery... no effect at all po yan... even if you use a bigger battery... OR a higher amp alternator.. same output 12-14.8volts... the output is regulated by the alternators IC....
    masisira lang yan kapag 24v battery ang gamit nyo...
Upgrading The Alternator's Charging
