Results 1 to 6 of 6
- Apr 2009
- 1
July 22nd, 2009 12:21 PM #1Good day to members!
I have a Toyota REVO GLX 1.8L EFI.
I recently detached the gauge clusters yesterday. Yung speedometer kasi di gumagana, tinangal ko yung gauges para malaman ko kung umiikot pa yung speedometer cable, pinaandar ko yung Revo sa village ng tangal yung gauge. Nakita ko na umiikot pa yung cable. So in short gawa yung cable at di putol.
Nilinis ko na din yung gauge clusters at nag replace ng bulbs, madilim na din kasi, para isang trabaho nalang. After cleaning and replacing the bulbs it was so bright na parang bago.
Binalik ko na at tinesting ko, nung pinaandar ko na, dun ko nalaman merong mali.
1st gear palang alam ko na. I usually change gears pag na reach ko na 3k RPM sa tachometer. Laking gulat ko ng umakyat bigla yung speedometer reading from 0-60kph at 1st gear palang!
Sobrang bilis umakyat. Nilabas ko ng EDSA at ganun pa din, 2nd gear palang 120kph na agad sa speedometer! 4th gear at lumampas na siya sa 160kph. 5th gear at nag full rotate na siya almost going back to 0hph.
Pag menor ko napansin ko din na ang bagal bumaba ng needle pointer ng speedometer. Pag full stop mo yung speedometer di ba siya agad nag 0kph. Parang nag "free float" pa siya bago mag 0kph.
I humbly seek advise on how to remedy and solve this issue. The ODOMETER and TRIP METER reading are fairly accurate naman. I go to the office with the same distance of 7.2km from my other car. Ganun din sa Revo nung sinukat ko kanina. Mabilis umakyat pero mabagal bumama. Yung km counters ok naman at di mabilis umikot.
Pls help!
THANKS!
August 26th, 2009 10:10 PM #2
may ginalaw po ba kayo sa speedometer itself? yung needle at spring sa likod?
November 24th, 2009 01:36 PM #3
we have the same problem. guys baka may naka experience na rin sa inyo
ng ganito patulong naman. ang hirap ng sira speedometer
- Dec 2010
- 9
- Dec 2007
- 7
January 7th, 2011 09:27 AM #6good am mga sir probably nawala sa alignment or na-dislocate yun pinaka-spring sa likod ng speedometer- meron yan spiral spring sa likod mostly nawawala sa alignment pag nagalaw ang speedometer, check if align then have it calibrated, pede din po i-DIY yan hope this will help.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
