Results 1 to 7 of 7
- Feb 2013
- 42
November 23rd, 2013 04:46 PM #1Hello mga katsikots,tanong nga ako kung bakit biglang pumapalo agad ung temperature gauge ko pag switch-on ko pa lang.pati ung RPM gauge nagflufluctuate din.ano kaya nangyari.wala naman akong ginalaw sa sasakyan.pero pag tumatakbo na bglang nagnonormal din.sa unang switch-on pa lang.patulong po sa may inputs tungkol dito.salamat.toyota liteace 2c-turbo sasakyan ko.
November 23rd, 2013 04:53 PM #2
Hmmmm, you mean unang start sa umaga pumapalo agad yun temperature mo?
November 23rd, 2013 06:51 PM #3
- Feb 2013
- 42
November 27th, 2013 04:25 PM #4ok sir jick.cejoko,tinanggal ko na kasi ung connection wire na nakakabit ca coolant reservoir kasi pag nakakabit ay palaging nakailaw ung low coolant indicator sa dashboard pero okay naman nung diniskonek ko kasi nawala lang ung ilaw.may kinalaman kaya ung koneksion na yun.salamat
- Mar 2010
- 2,273
November 28th, 2013 08:18 AM #5
November 28th, 2013 05:05 PM #6
used to have that before on a suzuki carry dropside. turned out na sira yung sensor/thermostat. when it happened again on another occasion. i realized na may tama ang radiator ko.
- Jul 2010
- 570
December 2nd, 2013 01:10 PM #7Palagay ko ay loose ground wire connection sa Temperature at sensors. Kaya umangat mga voltage reference papuntang gauge or ecu.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
