Results 21 to 30 of 30
January 18th, 2010 01:15 PM #21
Kung mahirap abutin yung alternator mas mabuti pa siguro na bago nalang ang ilagay. Dami puwede masira anytime sa alternator na surplus, usually bearing.
January 18th, 2010 07:23 PM #22
Ang suggestion ng mga electrical shop na gumagawa ng alternator kung IC may sira bumili ka na lang ng surplus na alternator dahil mahal ang IC nito.
January 18th, 2010 07:54 PM #23
January 18th, 2010 08:22 PM #24
I rather have my alternator repaired than buy a surplus unit. You'll never know when a surplus unit would breakdown. Pede rin, if the store agrees, kung open mo yun surplus unit to check the condition of the brushes, pero bihira ito unless close kayo ng owner...hehehe. Pag nirerepair alternator pag sira lang IC, palitan mo na din ng carbon brushes and the bearings at both end.
January 19th, 2010 09:12 AM #25
January 19th, 2010 10:51 AM #26
ang kulit tumawag ako sa Honda Manila para magtanong ng parts ndi nila alam ung IC Regulator???
January 19th, 2010 11:42 AM #27
Iyong altenator ko noong pinagawa ko naputol lang iyong wire sa pagkakarewind inayos lang nila kung sa iba ko pinagawa ito maaring sabihin i rewind na lang nila at lalaki gastos mo at pag bumili ka sa kanila ng surplus na alternator may Warranty .
RICO electrical Services
222 Iba St QC.
740-24-64
414-00-71
Rey ang pangalan ng owner at sabihin mo na lang iyong kasama mo sa motor nagrekomenda sa iyo.
Charge lang ako niya ng 400.00 kasama na service ng masiraan ako at pinagana niya sasakyan ko.
January 19th, 2010 05:09 PM #28
If you're from Makati, try calling Marco Auto Supply. 8903101, 8903657 look for Dong. They sell reconditioned alternators.
- May 2008
- 1
January 19th, 2010 08:12 PM #29How much ba yung IC ng alternator mga sir? Sabi ng mechanic mas ok pa daw if bumili ako ng surplus kaysa bbumili ako ng IC....
January 19th, 2010 10:31 PM #30
Sinwerte ako nagpagawa ako dun sa shop sa side ng Obeertime ung kanto ng Pasong Tamo and Dela Rosa Makati... Iniwan ko dun ung oto ko para maayos nila ng mabuti... Nagpunta pa ung technician sa evang para maghanap ng IC Regulator nakakuha sya 1,4k ayun gawa na ung alternator ko :D salamat sayo Rocky! Job well done! :D
To: Speed Unlimited, sir thanks sa referral pro oks na ung alternator ko saka medyo malayo din ung QC sakin. Thank you thank you padin
high idle RPM at engine start
