Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
    Sep 2005
    Sirs, the fog lights of my Innova is H16 12V 19 watts. H16 bulbs are very rare, can I use H11 12V 55watts instead? Is there any danger? BTW the sockets of H11 and H16 are the same. Fit na fit sya sa housing. Thanks
    Quote Originally Posted by ufl784 View Post
    Up for this, Ill be doing the same thing but for my vios naman po, thanks sa mkkasagot
    Jun 2012
    H16 is normally for Ford. The H16 in Toyota foglamps are actually H11 base.
    The PGJ19 base series common with H8, H9, and H11. Osram used H16 for their 19W bulb of this series.
    Quote Originally Posted by confused shoes View Post
    Thank God for an answer sir, so is it safe to assume that using h11 on foglamps in toyota is safe? I mean, even thought they have different wattage as stated
    Since mas mataas ang wattage ng H11, baka di kayanin ng original harness. Baka need mo ng harness kit with relay. If gagastos ka lang din for harness kit and relay, better na rin to settle for 3000K or 4300K H11 HID
    Sent from my LT26i using Tapatalk 2
    Exactly what I had in mind, naisip ko din na mapapagastos, then go na lang din sa H11 HID para mas maganda na talaga, thank you sir
    Aug 2012
    wala bang H16, 19W bulb sa Toyota casa? hindi naman siguro kamahalan kung bulbs lang, less hassle pa. Fog light color temperature is normally 2600K to 2800K. this gives best results. HID for fog lights are useless.
    Our 2008 Innova is using 51W foglights H11,- all stock.
    “The measure of a man is what he does with power – LJIOHF!”
    Duterte for President of the Philippines in 2016!
    25.1K:dog2:
    Aug 2012
    *TS: there you go, problem solved. use 51W, H11 instead or even 55W should be no issue.
    Ano nga kaya meron sa Toyota at puro H16 na fog lamp bulbs nila? It's useless eh ang dilim. Pati Innova pala at Super Grandia na dati naka H11, naka H16 na rin.
    In my experience ok naman 3000K sa fogs..
H11 and H16 Fog Lights Bulb
