Results 1 to 6 of 6
- Nov 2008
- 70
April 12th, 2009 04:05 AM #1I recently have a problem starting an 89 Nissan Maxima. Dati, from rest or kapapatay lang ng makina, 1 click start na agad... but now, kapag fresh galing sa biyahe at pinatay mo makina, eg pakarga ng gas, and once done, ayaw mag start, i need to wait 5 minutes to try and start the car again...
mag redondo for 2 sec then totally wala na maramdaman
any ideas?
thanks
THE AUTO SPECIALIST
- Mar 2006
- 607
April 12th, 2009 06:18 AM #2try this ;
charging test * idle 14v - 14.5v
cranking test at least you will get 9.6v minimum
batt voltage test ignition OFF
12.55 FULLY CHARGED
12.9V SULFATED PLATES
12V OR LESS DEAD BATT
12.4 V UNDERCHARGED ( check charging systems)
April 12th, 2009 03:00 PM #3
parang sa battery ang problema ng ride mo, try to check your battery cable -/+ kung mahigpit ang mga terminal at kung na full charge ang battery. baka dapat nang palitan ang batt. mo boss.
- Nov 2008
- 70
April 15th, 2009 03:00 AM #4tried swapping batteries kanina, same din ang nangyari..
sinubukan ng father ko adjust ang menor by moving the distributor, di na kasi naaadjust sa may screw (dunno why)
and wallah, nag-start.. tried moving it around a little, minsan mag-start minsan hindi, hanggang inabot ng diskarga
- Dec 2006
- 273
THE AUTO SPECIALIST
- Mar 2006
- 607
April 15th, 2009 10:49 AM #6tawag na lang ng mecanik bago ma mess up ang settings.
mas malaki ang magagastos pag may masirang iba dyan
