Results 1 to 6 of 6
    I recently have a problem starting an 89 Nissan Maxima. Dati, from rest or kapapatay lang ng makina, 1 click start na agad... but now, kapag fresh galing sa biyahe at pinatay mo makina, eg pakarga ng gas, and once done, ayaw mag start, i need to wait 5 minutes to try and start the car again...
    mag redondo for 2 sec then totally wala na maramdaman
    any ideas?
    thanks
    try this ;
    charging test * idle 14v - 14.5v
    cranking test at least you will get 9.6v minimum
    batt voltage test ignition OFF
    12.55 FULLY CHARGED
    12.9V SULFATED PLATES
    12V OR LESS DEAD BATT
    12.4 V UNDERCHARGED ( check charging systems)
    Sep 2008
    parang sa battery ang problema ng ride mo, try to check your battery cable -/+ kung mahigpit ang mga terminal at kung na full charge ang battery. baka dapat nang palitan ang batt. mo boss.
    tried swapping batteries kanina, same din ang nangyari..
    sinubukan ng father ko adjust ang menor by moving the distributor, di na kasi naaadjust sa may screw (dunno why)
    and wallah, nag-start.. tried moving it around a little, minsan mag-start minsan hindi, hanggang inabot ng diskarga
    Try to tighten battery connections, same as with the starter.
    tawag na lang ng mecanik bago ma mess up ang settings.
    mas malaki ang magagastos pag may masirang iba dyan
Starter or Alternator Problem?
