Results 1 to 10 of 24
January 28th, 2016 02:03 PM #1
I'm about to change my sparkplug. Ano ba ang mas practical at better performance copper or iridium? Thanks!
Sent from my H220 using Tapatalk
- Apr 2012
- 3,469
January 28th, 2016 04:15 PM #3
If you're replacing plugs every 10k or 20k, copper plugs should be fine.
In reality, copper has the best performance of all three and the worst longevity. Platinum has good longevity and the worst performance. Iridium has good longevity and a performance that is decent, which is why iridium plugs tend to be more expensive than any other type.
January 28th, 2016 07:13 PM #4
DIY Cleaning spark plug using softdrink and salt. it works for me...
January 28th, 2016 07:30 PM #5
Spark plugs of the right heat range and the engine at optimum performance should not need spark plug cleaning during its service life. If they get fouled like the ones our expert showed, it is a result of poor mechanical condition, poor fuel delivery, weak ignition coil output, high secondary resistance, bad fuel, restricted air intake. Correct the problem at the source
January 28th, 2016 08:38 PM #6
January 28th, 2016 08:39 PM #7
- Jul 2015
- 198
January 28th, 2016 09:13 PM #8Sir radz,choose the copper plugs. Replacing more often is more better than the iridium high life kuno that can be use for more thousand/s of kilometers. Pero manggugulo lang ng konti my APV consumes less fuel when I started to use iridium plugs.a difference of .5 - 1km to a liter. Kaso Iridium plugs cost around 2k per set unlike the copper plugs which is around 115 per piece sa suking auto supply.
January 28th, 2016 10:29 PM #9
for for the OEM recommended plugs. I've known cars na nagbago ang engine response to bad because of using non-recommended plugs.
ditto with what jick said.
January 30th, 2016 09:41 PM #10
Today's cars with tightly packed engine compartments will opt for longer life spark plugs due to the cost of labor for routine replacement. The removal of plugs for cleaning becomes a waste of time and use of the car. You might as well replace them when bad but fix the cause of the spark plug fouling. Cleaning them without investigating what is causing the carbon build up is only masking the result which becomes a chronic condition
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
