Results 1 to 16 of 16
    Nov 2007
    Peeps question nmn, kc ung aircon ko bgla n lng ayw gumana. pg check ko the heater relay sa fuse box under the hodd nasunog. After that pinalitan ko n sya. and my aircon works fine. pero after 2 days gmit ko ung aircon then bglang nmty ayw nnmn gumna. pg check ko ulit sa relay sunog ulit. pero all fuses are ok. ung relay lng. tpos mdyo sunog din ung pingkakabitan ng relay ko. help nmn dyan. nu kya un? short circuit? wiring? grounding? etc.... tnx sa help!
    definitely, it could either be short or grounding.
    Oct 2007
    please check if your relay socket is loose or your new relay might be under rated, check if same or higher ampere rating.
    After replacing your relay again, run for few minutes and touch it if it gets hot. when hot it is indication that it is over loaded
    Aug 2015
    Quote Originally Posted by trekker_1967 View Post
    Mga sir anu po ibig sabihin ng overloaded? Halos same problem kami, ung sakin sa radiator fan relay. Meron burn marks sa isang pin ng relay nung tinanggal ko. Inistart ko ng 15 minutes, ung ibang relay uminit ng konti, pero ung rad fan relay mainit talaga.
    Tumigil last week ung rad fan ko, pinaayos ko, sabi ng electrician may grounded daw, naayos naman, pinaltan na rin ng bagong relay.
    Inaalala ko lang ngayon ung burn marks sa relay, baka makasira tapos tumigil ung rad fan.
    Sabi ng electrician nakarekta daw rad fan ko ( pag on ng sasakyan bubukas na siya).
    Sa ngayon ok naman ung sasakyan. 2000 civic mt.
    Salamat!
    Quote Originally Posted by luffin View Post
    Salamat!
    relays have current or wattage capacities.
    overload means, the relay is conducting more electricity than it was designed for. because of this, the relay heats up and can die earlier than usual.
    why is your fan naka-rekta?
    perhaps you should ask the shop to revert your fan to the original factory spec and not naka-rekta.
    Aug 2015
    Hindi ko alam doc kung bakit nakarekta, tatanung ko na lang sa electrician. Sa mga nabasa ko dapat tumitigil din ang rad fan, tama ba? Kaya umiinit relay ko kasi tuloy tuloy ikot ng fan? Thanks
AC/Heater Relay got burned
