Results 221 to 230 of 383
- 54,226
May 11th, 2020 09:04 PM #221
- Nov 2009
- 3,507
May 11th, 2020 09:47 PM #222
May 11th, 2020 11:00 PM #223
May 12th, 2020 06:25 AM #224
May 12th, 2020 12:07 PM #225
It's been a while since I've purchased jumper cables. The set I have now have been through two cars in over a decade. But I do remember seeing different cables for use on gasoline and a chunkier option for Diesel engines. Since I was driving a 1.8L gasoline car then, I bought the cheaper, "for gasoline cars" cable.
Fast-forward to now, driving a 2.5L Diesel Innova, I am still using the same cable. I've used it to start another Diesel Innova without issues. It WILL get a little warm to the touch but not burning hot, even with sustained cranking.
You probably got really low quality ones. But then again, as long as it doesn't get too hot and you don't get into the habit of jumping your car everyday, that should suffice for emergency use. My jumper cable was used maybe a max of 5 times throughout its life.
If you jump cars for a living, however (professional mechanic, tow truck operator, etc.), then it's a good idea to use the necessary wire gauge for the application.
- 54,226
May 12th, 2020 12:14 PM #226from cold engine, we jump-cranked the dead innova several times, before it caught on.
that probably is the reason why the cables got uncomfortably hot.
- Nov 2009
- 3,507
May 12th, 2020 01:59 PM #227Unlike the older direct injection desel engines, Innova has glowplugs which require more battery juice to turn the starter and solenoid of fuel pump.
- Jan 2008
- 4,726
May 12th, 2020 03:23 PM #228Afaik.. innova with d4d engines are already direct injection.. electronic fuel pump only primes the system but the high pressure pump is driven by the engine.. also glow plugs turn on only for a few seconds..
What makes diesel engines hard to start is due to their high compression ratio.. and heavy internals compared to a gas engine
May 12th, 2020 03:37 PM #229
Correct. Couldn't have said it better myself.
As for the jumper cables heating up, I would like to add that the current flowing through the cable depends a lot on the state of charge of the installed battery relative to the donor battery. The lower the SoC of the main battery, the higher the current will flow from the donor battery. That what makes the cable go warm or hot.
It's not advisable to use run-of-the-mill jumper cables to start a vehicle without a battery. The jumper cable might not be able to handle the full current the starter requires.
May 12th, 2020 04:03 PM #230
experience ko sa diy 12 awg *2 wires total* (black for negative, white for positive) with panther clamps
pag may konting juice pa, like 8v reading yun auto; kayang kaya. pero yun totally deads na 2sm (mine is ns40), di nag start yun mazda 3 nun boss ko. baka doblehin ko yun white (positive), para maging 4 yun total. or dapat pati yun negative doblehin ko rin?
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
