Results 31 to 40 of 381
- 52,731
June 19th, 2014 12:52 AM #31i have no doubt it can be done. just some electronic magic to up the output voltage to more than 13.xx volts.. plug it into the cigarette lighter socket..
nice exercise to think about it..
i have seen solar panel that attaches to the window. the output voltage goes to the car battery via cigar lighter socket.. a variant of this is, the electricity drives a small electric motor that constantly blows (hot) air out of the cabin..Last edited by dr. d; June 19th, 2014 at 01:49 AM.
- Aug 2012
- 2,767
July 1st, 2014 10:19 PM #32already got myself the Suoer SON-10A Automatic Car Battery Charger. price was P1,600 with 3 months warranty from the OLX seller. free delivery.
i used it overnight last Saturday. i kept it plugged for more than 12 hours. simple to use, just connect to the car battery and power on, then you can forget about it. the LED displays the charging current being sent to the battery. once it shows below 1.0A, it means the battery is fully charged and ready for use. mine was showing 0.0A when i got to unplug it Sunday morning. this unit has "trickle" charge mode so you can leave it connected for indefinite period of time.
- Aug 2012
- 2,767
July 2nd, 2014 03:48 PM #33i used my digital multi-tester to measure open circuit battery voltage and it showed 12.78V which is just right based on chart below. car battery was Motolite Enduro 2SMF (Maintenance Free).
Open circuit battery voltage, for maintenance free (Ca/Ca) or VRLA (AGM or Gel Cell) 12V car battery:
12.77V = 100% (fully charged)
12.54V = 75%
12.29V = 50%
11.99V = 25%
11.75V = 0% (dead car battery)
Open circuit battery voltage, for standard (Sb/Sb) or low maintenance (Sb/Ca) 12V car battery:
12.65V = 100% (fully charged)
12.45V = 75%
12.24V = 50%
12.06V = 25%
11.89V = 0% (dead car battery)
i plan to use this charger once a month for battery conditioning/charge leveling.
July 10th, 2014 10:17 PM #34
- Aug 2012
- 2,767
- Apr 2010
- 739
December 17th, 2014 01:50 AM #36Someone disassembled and reviewed a Suoer 20A car battery charger, an older brother of the 10A that others bought: Suoer SON-20A 20Amp digital charger review
Quality leaves a lot to be desired - muntik ko na binili ito dati. Napapadalas short trips ko lagi so a charger is important to keep the battery in top condition
- 52,731
December 17th, 2014 02:33 AM #37
- Apr 2010
- 739
December 17th, 2014 10:02 AM #38^ Panther rin yung sa akin, rated at 6A max. Sulit pag may mga bagyo since I have a spare battery (yung pinagpalitan sa vehicle) to charge mobile devices, pwede ko pang i-negosyo
Kung kailangan nyo na palaging i-charge yung battery, probably may parasitic load kayo on key off, weak charging system or weak battery na hehe
- Aug 2012
- 2,767
December 17th, 2014 12:06 PM #39*ParticleX: sana lang walang ganyang issue sa Suoer SON-10A. yung Panther ba, may review na?
- Apr 2010
- 739
December 17th, 2014 05:23 PM #40According sa link na pinost ko, yung 20A can only deliver half of its rated capacity so expect ko na ganun din with your 10A unfortunately.
Can't find an in-depth review for Panther or similar manual battery chargers sa atin, meron sa Youtube ng walkthrough with the device. Nasubukan ko na giving a 5A load (6A max rating) sa charger ko and it could handle naman
As with these manual chargers eh expected na they are robust and will last long since it has fewer parts, wala nga lang advanced features (auto shut off, multi step charging process etc) - mostly pang flooded lead-acid batteries lang talaga (so no Optima or Bosch AGMs for example)
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
