Results 1 to 10 of 14
November 8th, 2010 06:00 PM #1
umiilaw po kasi or nag babattery check po ang dashboard ko, biglang humini aircon at namatay makina... ayaw mag start... tumirik po ako ng zabarte.. nag pa seriesna lang ako ng kuryente sa ibang oto.. pinipilit ko po sa sarili ko na battery lang ang problema kasi madaling palitan hehe... nung pauwi na po ako w/o ac only parklight lang.. humina ng humina hangan sa tumirik nanaman po ako sa sauyo... dun na po ako kinutuban na baka sa alternator ang porblema kasi db supposedly eh ma-kakargahan na ang battery ko kahit papaano... ayaw na talaga mag start hangan sa tinawagan ko po sister ko para hilahin yung oto.. haayz sobrang hassle po ngyari sakin kahapon.. kaka charge ko lang battery ko.. kabibili ko lang last may yung bat eh.. so does this mean that my alternator is really broken na??
honda esi matic
thanks.
November 8th, 2010 06:10 PM #2
sorry OT po: paano po na-tow ang kotse niyo na automatic?
might be you alternator or your battery. either sa dalawa muna yan. have it both check.
ilan years na ba battery mo? is it maintenance-free or low maintenance?
November 8th, 2010 06:19 PM #3
buhatin ang front end bro, and the rear end of the car is the one touching the road IMHO. Had this trouble also before, alternator din. You could source an alternator (heck get a higher amperage one para di bitin) for around P2k - P2.5k. Nasisira rin ang alternator as the car ages kasi.
- Nov 2009
- 456
November 8th, 2010 06:22 PM #4Baka naputol yung fan belt ng alternator kaya hindi nagkakarga ng kuryente sa baterya.
November 8th, 2010 06:24 PM #5
baka me problema nabili mong bagong battery? under warranty pa yan....
kung sa alternator, narerepair pa yan, baka carbon brush lang.....
- Jan 2005
- 445
November 8th, 2010 06:30 PM #6Tingnan mo muna ung obvious, battery connections baka maluag, alternator belt, tension ng belt. Then the alternator.
I doubt na battery yan, di ka titirik ng patay na battery kung buhay ang alternator mo.
November 8th, 2010 07:50 PM #7
bago lang battery ko last May ko lang ito nabili...
yun nga din hinala ko eh... kasi hindi talaga niya makargahan battery ko... kaka charge lang kanina morning coz naubos nga last night then after driving around our area nag battery check nananaman ako nag bblink nanaman. haayz. thanks sana makuha sa repair to., medyo pricey din pag nagpalit ng surplus. thank you guys.
- Jun 2010
- 76
- Jan 2005
- 445
November 9th, 2010 09:36 AM #9
November 11th, 2010 03:44 PM #10
napatakan daw kasi ng ps oil ang alternator ko kaya nasira, nasisira ba talaga alternator pag napatakan ng oil? di ba nag eevaporate naman yun? pardon me for my ignorance.
high idle RPM at engine start
