Not a good idea. If there's indeed something wrong with the circuit, doing that will cause a short and most likely pop a fuse on the multimeter.
I would suggest bringing it back to stock and disconnecting anything that was previously added then check again.
Oh btw, it is possible that when the parklights are off, both pins are connected to ground. That's usually how it is on signal lamps.
