Hi to all,
I'm planning to change my current alternator rated 90A to 110A. Please Advice if this is OK....recently i have installed HID for my headlight....
Hi to all,
Good day yes you can, but you have to change your battery too, by 12v 110ah.![]()
is there a battery rated 12V 110AH? my current battery is having 12v 75AH....Please Advice..thanks a lot...
You may have new alternator already but if you are still undecided, go for 110 amps, the one that gives high amps at low engine speed or idle as indicated in the specs otherwise baka sayang din. This should look bigger and heavier with bigger wires than low-amp alternator. You don't have to change the battery for this.
The other thing to consider is the pulleys should match at that rarting double belt na or 'B' size na yung belt na ginagamit.
Good luck.
Why would you need a new alternator? Hid systems usually have lower wattages compared to halogen? If indeed you have replaced your alternator, why would you have to replace your current battery? A good alternator has a cut-off when the battery is fully charged, especially IC types like those in the pajero.
I'am guessing your gonna get the one from the hyundai starex cause its a bolt-on to the 4d56, right?![]()
