Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    May 2005
    Share ko lang. Pag out of warranty na ang maintenance-free car battery nyo especially kung 2 yrs old pataas at mahina na, you can add battery solution - not distilled water, to prolong the life of your battery. Ginawa ko na ito at effective naman. Sunod ko advice ng taga battery shop na nakausap ko. Tanggalin ang battery sticker at unscrew the caps. Do not over fill.
    i suppose you can do that
    Quote Originally Posted by nansky
    question lang po? yun bang battery solution na sinasabi mo yun galing sa battery shop na binibigay ng FREE pag bumili ka ng low maintenance battery? afaik distilled water din yun.
    May 2005
    Quote Originally Posted by IIE
    Ung Battery solution ay acidic ung properties kaya medyo ingat lang. Iba ito sa
    distilled water.
    Jul 2003
    not! when you buy a new battery the first fluid to be pour-in, is the Acid battery solution for self charging, then upon using the battery the fluid may evaporate, to top up just add distilled water nalang.
    ako naman, i don't buy low-maintenance car battery. i still prefer the old-style car battery.
    Quote Originally Posted by zero
    me too.just regularly checking the water inside.dapat laging covered yung plates
    May 2005
    The problem with maintenance-free or low-maintenance batteries is that they have sticker covers at the top. If you remove the sticker to unscrew the battery plugs, it will void the warranty.
    The advantage is, as the commercial states: Ikabit then forget. However, after some time (about 2 years) nababawasan ang liquid sa loob ng baterya, hindi na above the plates so simula na ng pagkasira ng baterya.
    Jun 2005
    yun yung solution na nilalagay para sa mga battery repairs... if i remember it correctly, kinakain nito yung mga metal sa loob ng battery para magproduce ng chemical reaction taht would result in electricity. okay din ito pero in the long run, mauubos yung metal plates ng battery kaya patay na din... may mga issues din dito...
    Jun 2004
    allow battery to be charge 12.8v++ more often..
    Jun 2005
    id rather by new batteries na lang mahirap na kasi baka tirikin in the middle of nowhere im actually more concerned about where to disperse of my used battery kasi delikado yan sa environment
    Jan 2003
    pag out of warranty na battery ko, i have it checked montly sa mga battery shops.
    bigyan mo na lang tip yung mag test
    what i do is to remove the negative terminal connection every night or when the car is not in use. seems to be working
    Jan 2004
    or better yet, buy something na ok. yung outlast battery ok, sya almost 3 years na good pa rin. kaya lang medyo risky na din.
    May 2005
    There's no substitute for a a brand new battery especially the good ones - Motolite, Outlast etc.., pero medyo mahal. Kung kapos sa budget at nag-iipon pang bili ng bagong baterya, pwede munang gawin ung alternative.
    Feb 2005
    ok siguro kung every 2 yrs ka mag palit. mahirap pag namamatayan ng battery.
    It happened to me sa ortigas ctr. tamang tama nasa gitna ako ng crossing, ayun! biglang namatay ang makina, ganun pala ang EFI, tapos dahan dahang tumigil. ayaw mag "redondo?" ... kaya TULAK hehehe.
    go for low maintenance pero regularly check the battery once it's out of warranty period na. you may dispose your battery by trading it for a new one. It costs around P50 - P100 php.
    turn off the aircon thermostat (blower fan on) few hundred meters from destination, turn off headlight/radio at night when entering our garage. enough charge for tomorrow's start up. it helps.
    Oct 2003
    hindi ba by removing the negative terminal sa battery resets your radio presets and clock if any? or is it only by removing both terminals?
    Quote Originally Posted by zechs
    yap, you need to reprogram your electronic devices once you disconnect negative terminal.
    unless your car stereo has a battery for the memory presets (backup battery). My stereo has one.
Prolonging Car Battery Life
