Sira yung isang HT wire meron ba nabibili lang ng isang piraso o by set? at magkano po kaya? car is 97 lancer glxi. masama ba pag di ko agad pinalitan?
thanks
thanks
i've just asked that item at El-Dorado sa Pedro Gil and they quoted me 1900 for a set.
I'm sure meron pang makukunan na mas mababa, maybe sa ATCO sa Pasay or sa Shaw Merchandise (not sure of the name) yung sa tapat ng JRU sa may Kalentong, try mo din sila.
not sure if makakabili ka pc by pc. siguro you can go to the surplus engine stores in banawe and ask if meron sila mabebenta sayo na 1 pc. if not, then best to get the set na talaga.
fuel economy will suffer if the wires are not performing up to spec, as well as the possibility na malulunod yung isang cylinder mo where the wires are not firing correctly.
speedyfix ano b ang magandang brand ng HT wires para sa revo. nagtanong kasi ako ng 5 star 2800 , splitfire 3500, blue thunder denso 5600 4 core.?
migs bkit wala rin tinda na HT wire na my socket na kamukha ng sa 7k ico-convert lang daw nila ung socket nung spark plugs par magfit sa revo.k lang ba un?
As far as I know, you have to buy the high tension wire as a set, and not on an individual wire basis.
jevy, the main reason walang nagbebenta ng ht wires for your car is because konte lang nagmomodify nyan. hehe! i wouldn't want to have converted sockets for my car. baka magkaproblems ka pa nyan in the future kapag lumuwag or something. stick to stock nalang. no diff naman kung magpalit ka eh![]()
From experience, the best is to use OEM wires if your car is basically stock or not heavily modded... If you're changing one, its best to change all since they also deteriorate over age if i may add.
speedtfix. i have here my denso iridium eh 2 months na ngang naka stock d2 sa haus eh. sabi nung sa denso sa banwe mas ok daw kung magpapalit ako ng HT para magamit ko ng lubos ung power ng spark plugs. totoo ba yun o maski stock lang ung HT wire eh ok pa rin? ano diff bet. the stock HT with the aftermarket HT wires?tnx migs
Bandido, usually companies like NGK manufacture stock or OEM wires.
jevy, sounds like sales talk to me. try mo nalang kung ok yung performance kapag kinabit mo. kung ok then sulit nabili mo. if not then na-sales talk ka siguro nya.
main difference is the diameter of the inner conductive core and sometimes iba rin yung material na ginagamit nila (copper because this is a good conductor of electricity).
speedy sabi kasi ni felix pagnilagyan ko daw ng new spark plugs specifically the iridium spark plugs ay kailngan daw i tuneup pa ulit.tha is possible?tnx speedy
With regard to aftermarket plugs and HT wires, dyno tests have shown that they dont improve HP/toque whatsoever AFAIK.
no naman. i doubt magiiba naman takbo. baka he was referring to something else lang
pero ingat sa iridium ha! baka madali yan masira kung stock lang makina mo.
I agree I think theres no one sells a hi tension wire pc by pc..It is always 1 set....As far as I know, you have to buy the high tension wire as a set, and not on an individual wire basis.
ganun speedyfix madaling masira ung spark plugs pag stock lang ung ride mo? maski naka muffler at intake ka na?tnx migs
ok I just called up ATCO and they told me that 1 set of OEM HT wires would cost around 1,600. baka dito ko na lang bilin para mapalitan na agad...
Ty sa mga replies
depende sa heat range ng kinuha mo. if you got the ik22 or ik24 then i think madali sya masisira. kung ik20 lang then baka ok lang sya for your car.
