ano po ba masmagandang adjustment ng camshaft 2dgrees advance or retard? sa intake or xhaust? pra lumakas rangkada between 2nd n 3rd gear? nlilito kc ako![]()
pa-dyno mo nalang yan. sayang if you can buy camgears pero can't spend to tune them correctly.
I assume you're talking about changing the distributor timing? 5-10 degrees advance is the safest to run, depending on your vehicle... but if you want more power from advancing the timing, you'll need to spend on better gas.
uhm on a honda sir, 16 is stock. going up to 18-20 is kinda normal na.
