Results 1 to 4 of 4
    Aug 2005
    ano po ba masmagandang adjustment ng camshaft 2dgrees advance or retard? sa intake or xhaust? pra lumakas rangkada between 2nd n 3rd gear? nlilito kc ako
    Nov 2003
    pa-dyno mo nalang yan. sayang if you can buy camgears pero can't spend to tune them correctly.
    Aug 2004
    I assume you're talking about changing the distributor timing? 5-10 degrees advance is the safest to run, depending on your vehicle... but if you want more power from advancing the timing, you'll need to spend on better gas.
    Nov 2003
    uhm on a honda sir, 16 is stock. going up to 18-20 is kinda normal na.
camshaft low end power
