Results 1 to 4 of 4
August 23rd, 2005 12:48 AM #1
ano po ba masmagandang adjustment ng camshaft 2dgrees advance or retard? sa intake or xhaust? pra lumakas rangkada between 2nd n 3rd gear? nlilito kc ako
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 24th, 2005 11:30 AM #2pa-dyno mo nalang yan. sayang if you can buy camgears pero can't spend to tune them correctly.
August 24th, 2005 12:53 PM #3
I assume you're talking about changing the distributor timing? 5-10 degrees advance is the safest to run, depending on your vehicle... but if you want more power from advancing the timing, you'll need to spend on better gas.
- Nov 2003
- 3,849
August 25th, 2005 12:03 AM #4uhm on a honda sir, 16 is stock. going up to 18-20 is kinda normal na.
Monk-owned R53
