Results 1 to 12 of 12
    Anyone experienced this??? Ano ginawa ninyo??? Oil is leaking from my alternator every (cold) morning but when it warms up the leak stops. I'm planning tuloy to replace my alternator 'coz I have an extra one.
    Jun 2005
    AFAIK wala naman oil sa alternator. it just some electric winding/electromagnet, 4 rectifier diodes and a regulator plus some pulleys and bearings. wala ako alam na oil. probably ur engine is leaking somewhere. better look for the leak sa engine.
    merong oil talaga eh. saka hiwalay yung alternator ko sa engine so makikita talaga yung pinang-gagalingan ng leak. may hose din from my oil pan connected to my alternator. anyway baka palitan ko na lang yung alternator. ang prob ko mataas ang AMP rating ng ipapalit ko baka kelangan ko ring palitan wirings ko pag sakali.
    May 2004
    pag diesel me oil line papunta alternator. naputukan na kami dati nyan. ang pinagtataka ko lang sayo e stop yung leak pa maiinit na yung makina. strange.
    hmm never heard of an alternator necessitating oil... as in never.
    Aug 2005
    me too never.. maybe some lubrication.. huh?
    Apr 2005
    paki check uli, never an alternator has oil. it is an electric device. it should be coming from the engine just passing thru your alternator, baka makaroon pa ng short circuit yong wiring mo.
    Apr 2004
    Most diesel engines have an alternator that recirculates oil to create AIR vacuum, which is needed for the hydrovac and other actuators.
    jim; most probably its in the hoses, 2 actually, the intake and the discharge.. if its oily, most probably it has a leak.
    umuubos ng engine oil yan pag malakas ang tagas at pag hindi mo pinansin. tama po si v22, may air yan for the hydrovac brake system and other components that needs air like idle up switch, diff locks, etc.
    sir niwde11, sir v22 and sir afrasay: yup yun nga yun. pero tlagang nagtataka ako pag nag-warm up na wala na yung leak. nawiwirduhan tuloy ako. pero pag unang startup sa umaga talagang pumapatak yung oil. titignan ko rin yung hoses at connection baka dun nga lumalabas. nung una kong makita ito akala ko tubig kasi sa may water hose from radiator ko pumapatak at pinadudahan ko na yung water pump ko baka may leak. pero nung hinawakan ko oil pala tsk tsk tsk.
    malayo po ang water pump diyan. pag-umaandar di mo mapapansin kasi oil gets blown away or drys out due to heat. may small tube yan from the block whcich supplies the oil to the alternator.
    Quote Originally Posted by afrasay View Post
    I now have signs on my bypass hoses on my 50kkm GS.
    The hoses are now moist, but no oil leak yet.
    Need to replace both as soon as possible....
Oil Leaking sa Alternator
