Results 1 to 10 of 12
October 17th, 2005 12:03 PM #1
Anyone experienced this??? Ano ginawa ninyo??? Oil is leaking from my alternator every (cold) morning but when it warms up the leak stops. I'm planning tuloy to replace my alternator 'coz I have an extra one.
- Jun 2005
- 3,774
October 17th, 2005 12:33 PM #2AFAIK wala naman oil sa alternator. it just some electric winding/electromagnet, 4 rectifier diodes and a regulator plus some pulleys and bearings. wala ako alam na oil. probably ur engine is leaking somewhere. better look for the leak sa engine.
October 17th, 2005 12:57 PM #3
merong oil talaga eh. saka hiwalay yung alternator ko sa engine so makikita talaga yung pinang-gagalingan ng leak. may hose din from my oil pan connected to my alternator. anyway baka palitan ko na lang yung alternator. ang prob ko mataas ang AMP rating ng ipapalit ko baka kelangan ko ring palitan wirings ko pag sakali.
October 17th, 2005 01:08 PM #4
pag diesel me oil line papunta alternator. naputukan na kami dati nyan. ang pinagtataka ko lang sayo e stop yung leak pa maiinit na yung makina. strange.
Toyota is my choice
- Aug 2005
- 2,063
October 17th, 2005 01:51 PM #7
paki check uli, never an alternator has oil. it is an electric device. it should be coming from the engine just passing thru your alternator, baka makaroon pa ng short circuit yong wiring mo.
October 17th, 2005 02:00 PM #8
Most diesel engines have an alternator that recirculates oil to create AIR vacuum, which is needed for the hydrovac and other actuators.
jim; most probably its in the hoses, 2 actually, the intake and the discharge.. if its oily, most probably it has a leak.Last edited by v22; October 17th, 2005 at 02:03 PM.
October 17th, 2005 02:25 PM #9
umuubos ng engine oil yan pag malakas ang tagas at pag hindi mo pinansin. tama po si v22, may air yan for the hydrovac brake system and other components that needs air like idle up switch, diff locks, etc.
October 17th, 2005 02:42 PM #10
sir niwde11, sir v22 and sir afrasay: yup yun nga yun. pero tlagang nagtataka ako pag nag-warm up na wala na yung leak. nawiwirduhan tuloy ako. pero pag unang startup sa umaga talagang pumapatak yung oil. titignan ko rin yung hoses at connection baka dun nga lumalabas. nung una kong makita ito akala ko tubig kasi sa may water hose from radiator ko pumapatak at pinadudahan ko na yung water pump ko baka may leak. pero nung hinawakan ko oil pala tsk tsk tsk.
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
