Results 11 to 16 of 16
- Oct 2009
- 2,271
October 22nd, 2013 02:59 PM #11may roong hindi naisaksak mabuti na socket kaya ganyan yan..hindi sumagad sa lock..kaya result loose connection in & out ,,
- Jul 2012
- 113
October 25th, 2013 08:19 PM #12FRIGID ZONE sir, binalik ko nung isang araw pero hindi nagawa, may nabasa ako na baka nagalaw na yung airbag kaya hindi niya binibigyan ng power yung sa part ng horn, okay yung clock spring, hindi putol, pero hindi nila alam don kung ano ang clock spring. San kaya pwede to ipa-check sir? May idea kayo?
- Jul 2012
- 113
October 25th, 2013 08:21 PM #13mga Sir, may alam ba kayong okay na electrical shop near Munoz QC?
Pa-check ko muna to weird kasi, nawawala yung light ng AIRBAG kapag pinapatay then open ulit, pero after mag drive for few minutes babalik ulit ang light.? any one experience it na po?
July 29th, 2015 09:33 PM #14
Ask ko lang po pano po na resolve ito....ito kasi nanyari sakin kanina...nawala din horn at umiilaw un airbag..di ko binayaran ang taga gawa ng AC,,,ang sabi ng electrician putol daw un connector (CLOCK SPRING ??)..kasi daw nasubrahan ng pihit.di daw dapat pinipihit yun manebela ng sagad kun binabalik un manebela...
- Jan 2008
- 4,726
July 29th, 2015 09:42 PM #15Palit clock spring yan or kung kaya pa pwede solder lang. May procedure kasi sa pag tanggal ng steering wheel with airbag. Dapat nasa center yung steering then pag remove dapat i lock yung clock spring mechanism para hindi mawala sa tamang turn
July 30th, 2015 07:10 PM #16
The first step in removing the steering wheel or steering components is to point the tires straight. I remember an inexperienced coworker change the pitman arm of an 8 cubic yard dump truck. When the operator took it out on a mission, it could only do straight or right turn. No left turns. Imagine that. Give the job to the professionals. Iwas sa uhugin na "mekaniko"
Xiaomi E-Car
