Results 1 to 10 of 10
June 24th, 2008 03:40 PM #1
marereset ba ang ecu if i remove the old battery terminals and replace them with new ones? ano pa po ba ang marereset?
June 24th, 2008 04:30 PM #2
i assume your car is a civic (based on information on your profile).
ang alam ko sa civic if the batteries or one of its terminals are disconnected by 10 minutes, reset na ang ECU.
without removing the batteries, ECU can be reset by removing the ECU fuse.
i might be wrong though.Last edited by 1D4LV; June 24th, 2008 at 04:33 PM.
June 28th, 2008 09:43 PM #6
Removing battery terminal for more than 5 minutes will reset the Keep Alive Memory (KAM) and will return the ECU or PCM to its default setting. After resetting the ECU and KAM, vehicle may exhibit certain driveability concerns. Adaptive learning contents such as idle speed and fuel trim are included. It will be necessary to drive the vehicle to allow PCM to relearn values for optimum drieability and performance.
Source: Mitchell1 (OD5)
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 4th, 2008 08:37 AM #7Maki ride na ko sa thread.
Will removing the battery terminals for more than 10 mins clear a CEL? Or do I need an OBDII scanner to clear it? I'm asking bec a defective high tension wire caused misfiring and lit up my CEL. Car is a Chevy Venture.
THE AUTO SPECIALIST
- Mar 2006
- 607
September 4th, 2008 09:37 AM #8
THE AUTO SPECIALIST
- Mar 2006
- 607
September 4th, 2008 09:40 AM #9
- Jun 2006
- 2,605
September 5th, 2008 08:46 PM #10
Xiaomi E-Car
