Quote Originally Posted by stolen*soul View Post
salamat sir. ngayon tinatry ko magistart. bagong charge ang battery ko, nagstart siya isang beses kaso kinailangan kong patayin ung makina. after 30 mins, nung nitry ko istart ulit. wala na. may redondo pero mahina. battery pa rin kaya?
if your car's electrical system has not been tampered with and the wirings are proper, the short would cause a fuse to blow. the only circuit not passing thru a fuse would be your terminal 30 from the battery positive to the 30 of the starter solenoid or starter relay. in your case, i would check the circuits that are not fused yet. if this symptom were water intrusion induced, check the fuse panel around the kick panel.
