Results 1 to 3 of 3
    Sep 2013
    Nadiskarga po last night mazda 3 2007 ko. Ganto po nangyari Inistart ko ,then after 10 mins off tapos on ang hazard. Hazard lang talaga naka on siguro for 45 mins din. Tapos ayaw na umistart kaya jinump start nalang then nag start na. Pero ngayon mabilis naman na nag sstart. Ano po kaya reason bakit na diskarga? Motolite 1smf po size at 7 years na ata yung battery haha. TIA po
    Quote Originally Posted by Ciz View Post
    1. i think 7 years is already way past replacement time. you are perhaps just lucky this battery lasted so long..
    2. starting a car eats up a lot of juice. running the engine for 10 minutes is probably not enough to re-charge that battery to starting ability. then blinking your lights for 45 minutes, it probably ate up your 10 minutes of charge..
    have your battery tested po. my guess is, it needs replacement.
    Sep 2013
    1.Not sure sa 7 yrs po pero sa records wala talaga ako nahanap na nag replace o charge ng battery. So probably 7 years na talaga. Ano po ba lifespan ng battery ng cars?
    2.ask ko lang rin po para san ba yung nilalagyan ng tubig yung sa battery? Thanks po
Nadiskarga, with only the hazard lights were on
