Results 1 to 8 of 8
    Apr 2009
    guys, may marecommend ba kayo na nag aalign ng mga power window? kasi pag pinress up ng window, nawawala sa alignment yung salamin eh, kelangan ko pa tuloy hawakan yung salamin para ma align lang pag sinasara. salamat
    Apr 2009
    ako din i have the same problem.
    is there any place here in the south that can fix this? (Alabang area)
    May 2007
    Window regulator or guides depending on the vehicle. There are no generic or universal correct answers to your question, more info is needed like what kind of car it is.
    Anyway, there are ways to fix this problem,open the door panel and see if you can replace the window run channels,or spray some good lubricant down the Chanel's where the glass slides up/down,either way it will fix the problem.The reason the windows do this is the Chanel's wear out after a period of time and windows move to one side as they come up so they bind against the Chanel's.
    sometimes, if your window is the one with plastic mountings on the regulator, nauupod yung plastic na yun kaya gegewang yung salamin. sometimes, retightening of the screws will do, sometimes, replacement of the worn components.
    Aug 2004
    May nabibili bang plastic cable guides for the windows or surplus na lang talaga pagasa?
    Apr 2009
    may alam ba kayong magaling mag ayos ng mga mis aligned na window?
    Nov 2007
    up ko lang po to. magpapaalign din po ako
    Jan 2003
    Quote Originally Posted by webmonster View Post
    madaming gumagawa nyan sa evangelista. if your in the south, dun sa alabang town center, beside the church. alomng alabang-zapote road meron din mga gumagawa, not sure yung mga name ng shop. normally, sila yung may mga rubbers & window parts na nakadisplay.
misaligned power window
