guys, may marecommend ba kayo na nag aalign ng mga power window? kasi pag pinress up ng window, nawawala sa alignment yung salamin eh, kelangan ko pa tuloy hawakan yung salamin para ma align lang pag sinasara. salamat
ako din i have the same problem.
is there any place here in the south that can fix this? (Alabang area)
Window regulator or guides depending on the vehicle. There are no generic or universal correct answers to your question, more info is needed like what kind of car it is.
Anyway, there are ways to fix this problem,open the door panel and see if you can replace the window run channels,or spray some good lubricant down the Chanel's where the glass slides up/down,either way it will fix the problem.The reason the windows do this is the Chanel's wear out after a period of time and windows move to one side as they come up so they bind against the Chanel's.
sometimes, if your window is the one with plastic mountings on the regulator, nauupod yung plastic na yun kaya gegewang yung salamin. sometimes, retightening of the screws will do, sometimes, replacement of the worn components.
May nabibili bang plastic cable guides for the windows or surplus na lang talaga pagasa?![]()
