Results 1 to 4 of 4
April 17th, 2009 02:46 PM #1
Is this a sign that it's nearing the end of it's life span? It's going to be 3 years old this June - OEM battery.
Should I replace it now or use it till it dies?
Thanks sa replies
April 17th, 2009 02:59 PM #2
yup its a sign of nearing its life span. its nearing to be fully discharge. prepare a replacement battery.
you can replace it already or wait for it till it dies.
- Nov 2008
- 641
April 17th, 2009 03:10 PM #3Chief, better replace it immediately as the swelling is a bad sign of the battery condition. I'm not threatening, but due to experience, several of the swelling batteries which I saw, ended up in exploding, I'm not saying it will happen to you but better be cautious than not . 3 years of service is already a "milestone!". Good luck chief!
April 17th, 2009 03:23 PM #4
Sir, I think you should replace it immediately. I think you shouldn't wait until the battery dies, because if ever an emergency happens ( knock on wood ) we don't know if your old battery will still bring you to the place where you should need to go. Or if you want to use your batter until the end, better bring a new one and put it in your trunk.
high idle RPM at engine start
