Results 1 to 14 of 14
    Aug 2015
    Mga sir, is it "normal" na lumuluwag yung battery terminal sa mga AT unit?
    My trailblazer LT was just delivered Jan 8, we went back to the dealer Jan 14 kasi ang lakas ng kabig ng manibela pa-kanan, we got the unit the same day din naman.
    Last Sunday, we went to Monasterio de Tarlac (from Muntinlupa) naka park kami and when we were about to leave ayaw nang mag start as in walang power, a few minutes later we tried again, nag start naman. Then it happened again last night for just a few minutes.
    Today, we used the car just to see kung talagang may problema, we were in shell slex nung hindi na talaga nag start. We called road side assistance and when the tow truck arrived, they said loose daw yung terminal ng battery, exact word is "maluwag, ganyan talaga, automatic kasi eh".
    Is this normal? Should we expect this to happen all the time? We're planning to bring it to the dealer to have it checked but we are seriously considering to have the whole unit replaced. It was just delivered 11 days ago and twice na syang bumabalik sa dealer because of problems. Im just not sure if our dealer would allow us to have this replaced.
    Feb 2009
    What battery terminal configuration do you have? Top post? Side terminals? Either one it should not loosen itself when installed right. Maybe your cables are a tad too long. Maybe your cables are allowed to move.
    Aug 2015
    Top post sir.
    Jan 2009
    Depending on the kind of repair that was previously done, they may have removed the battery to get to an underlying part. Chances are, it wasn't re-tightened properly.
    The comment of the tow truck mechanic about your vehicle being an automatic, probably just meant that there's no way for you to start it (ie. Push-starting/bump-starting) other than through its own starter (ie. Battery power).
    Feb 2009
    Is the battery secured by the hold-down?
    Aug 2015
    yes it is.
    Apr 2015
    Its good you got a Trailblazer. Some other car with loose battery cable end up differently.
    Quote Originally Posted by chatteraddict View Post
    LT variant din ang sa akin at nagpa align din ako the first time i noticed yung misalignment. Good thing wala ng ibang naging problema thereafter.
    Walang connection ang AT vs. sa pagluwag ng battery terminal. As other has pointed out, may kumalikot sa battery terminal mo at nakaligtaan na hapiting maigi nung ibinalik.
    Aug 2015
    Medyo frustrating lang Sir kasi nagpapatong patong issue namin sa unit. May nakita kaming parang hardened rugby sa roof, maliit lang naman pero hindi namin matanggal, we had to request the dealer to take it out, we didn't make a big deal out of it because we failed to report it agad, then there's the misalignment and until now may konting kabig pa din pero not as bad as the first time, then itong terminal. On top of that, the head unit I requested was not the one that was provided, my sales agent admitted that some information he gave me was incorrect and that it was miscom on his part.
    When we bought our Strada and Fiesta we never had this much problem.
    Oct 2009
    minor problem kung walang power dapat inisip mo muna i check ang battery kung maluwag or hindi, para ikaw mismo alam mo ang naging problema ng sasakyan mo..
    kung na check mo ang battery terminal ay mahigpit naman at maayos.aba aba may problema ang bagong sasakyan mo..
    battery terminals do not magically loosen.
    either the terminal was not tightened properly, or battery acid ate up some of the metal...
    and no, AT and battery terminal are not related.
    Jul 2012
    Kung loose terminals tapos may mga kulay green na deposits kang nakikita sa paligid ng terminals ay mahihirapan ngang mag start yan. ang best remedy dyan ay linisin mo muna at tanggalin ang mga green deposits using steel brush at liha. Kulapulan mo ng grasa ang terminal para di na mag karoon uli ng corrosion.
    Oct 2014
    Pag ayaw mag start, wag agad i-rule na battery for replacement agad. Check double check ang battery connection. Learned the culprit several times by experience.
    Feb 2009
    the battery needs a little attention too. at least everytime you have the bonnet open, check the battery connections for tightness and cleanliness. both the terminals and the battery top needs to be free of dirt and liquids. if you have a voltmeter, check the voltage drop between the battery post and the battery clamp on the same pole by placing a considerable load, e.g. the starter motor. while an assistant cranks the engine, measure the voltage drop across the connections both on the positive and the negative side of the battery. the voltage drop should be no more than 0.5VDC.
    if the battery has vent caps and is designed to be topped off with battery distilled water, check for the electrolyte specific gravity. the S.G. of a fully charged battery should be between 1.260 up to 1.265 at our ambient temperatures
Loose battery terminal - Trailblazer AT
