Results 1 to 10 of 10
    Mar 2016
    Will the speedometer read the same KPH/MPH on Automatic or Manual transmissions
    Aug 2004
    There should be no difference. The speedo counts the number of times the wheels turn and doesn't care about the transmission type. Your speedo will be out of calibration if tires of a different diameter than the norm are used.
    No difference. JohnM already explained it above.
    Mar 2016
    Thank you for the replies sirs. Btw, where do this cables/wirings of speedo attached? Nalilito kasi ako sa tinatawag nilang gearbox ba yun? May problema po kasi yung speedo namin, di pumapalo yung needle niya, ok naman speed sensor, sa connection sa dashboard na po kaya yung problema nito?
    Aug 2004
    Quote Originally Posted by gradwaiting View Post
    There is a cable that runs from your speedo to a gear inside the gearbox/transmission. Baka putol na.
    More info here: How Speedometers Work | HowStuffWorks
    Mar 2016
    thank you po sir sa link. May alam po ba kayo na pwede mabilhan ng motor ng gear sensor? may ganoon daw po kasi sa banawe kaso masyado malayo. Ginagamit po siya pangtest ng speedometer gauge
    Sep 2012
    Para sa anong car ba yang tinatanong mo bro?
    Dalawang klase kasi yan... cable type na may gear sa dulo and meron din electronic speed sensor...
    Sent via Tapatalk
    Mar 2016
    Quote Originally Posted by jodski View Post
    Sent via Tapatalk
    yung ganito po na speed sensor
    http://honda-tech.com/attachments/ac...electronic.jpg
    Sep 2012
    Electronic speed sensor kamukha ng pang Honda.
    Sa surplus sa Evangelista meron nito... Hindi ko lang matandaan yung price nung binili ko dati for Accord
    Sent via Tapatalk
    Mar 2016
    Mga sir, mabalik lang po sa topic, bakit po pareho lang ang readings ng speedo nila kahit sa magkaibang transmission? any articles/links po na nagpapatunay dito? Wala kasi ako mahanap po. Thankyou po
Is there any difference in speedometer reading if you are automatic or manual
