I've noticed lately that whenever I turn the ignition key on, I would hear a kayod sound after the engine starts. I am afraid of whatever it is that getting kayod. Thanks.
ooops, after the engine starts pala. i guess first thing to check is if your high tension wires are properly inserted.
Do I bring that to an electrical shop? I'm afraid to bring it to just any mechanic 'coz my car ends up with more problems most of the time eh.
Can you guys recommend a place where I could bring it? I drive a 96 GLi Corolla
Why? What could be the problem? You're scaring me. hehe.
No squeal when I rev the engine. It's only when I turn the ignition key on.
madali lang yun maam baka contact or solenoid langmadali naman bakalasin ang starter ng gli
baka worn out bendix drive ng starter? go to an starter and alternator shop to unhook and inspect. it will kill your flywheel gears.
Sorry I meant before the engine starts. Basta after I turn the ignition key. Yung tunog niya yung parang pinipihit mo pa rin yung ignition kahit naka start na.
mam pa home service kayo kung ganun ang nararmdaman nyo sa oto nyo baka sumasama na ang starter nyan sa andar ng engine masusunog po ang starter nyo
possible problems are:
1. Bendix - responsible for engaging the starter to the flywheel and at the same time triggers the starter motor (this also acts as a relay switch)
2. Copper bushings - worn out copper bushings may cause hard starter movement therefore resulting to high current flow on the line making the bendix to chatter (just like a relay with poor current flow)
3. Loose connection - can result to high current flow resulting to chatter of bendix contacts
you just need to bring your car to a friendly neighbor hood electrician to pull your starter down and replace worn out parts.. I suggest you have the bushings replaced first..
Thanks. It's not a complicated job naman? Can anyone recommend a place in Makati, Paranaque or Alabang Zapote?
