Results 101 to 110 of 117
- Sep 2010
- 3,058
March 17th, 2023 12:34 PM #101
- Sep 2016
- 2,348
March 17th, 2023 12:37 PM #102
March 17th, 2023 12:47 PM #103
I'm actually planning to get this one since my power bank is due for a replacement... might as well get one that can start my car/motorcycle (if required)
TYLEX XP15 Car Igniter Powerbank 9600mAh 3.7V 2 Inputs & Dual Outputs 350A Start Current 700A Peak Current 12V Start Voltage
- Jan 2008
- 4,726
March 17th, 2023 12:50 PM #104smarty smarty na po yung mga portable battery jump starters.. i think they're safe to use na.. some even detects if you place the clips incorrectly..
usually the spark / spike in the initial clamping of the terminals that cause errors to the system.. that's why these portable jump starter need to be clamped first in the battery before you turn them on.. some have independent circuit for the jump starting that raises the voltage to the charging voltage of 14..
- Jan 2008
- 4,726
March 17th, 2023 12:53 PM #105
March 17th, 2023 03:06 PM #106
Are these jump starter powerbanks advisable to be left on the car in case of emergency? I was thinking of leaving one Sa lagayan ng spare tire. But I'm afraid if the car will be left in a hot sun the powerbank may start a fire.
March 17th, 2023 03:47 PM #107
- Sep 2016
- 2,348
March 17th, 2023 04:18 PM #108
March 17th, 2023 06:40 PM #109
March 18th, 2023 01:46 PM #110
I'm oldskool and just keep a pair of jumper cables in the car. And even that, in the last almost 8 years, haven't had a need to use it.
Anyway, if you are looking for portable jump-start packs, choose one that has LiFePO4 (LFP) cells. Unlike Li-Po or Li-ion cells, LFP does not spontaneously combust. They're safe for storage in your car.
Are they on track to surpass last year's sales?
Car Sales Data (2025)
