Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 101 to 110 of 117
    Sep 2010
    #101
    anyone here who still uses one? can it really start your car?
    Honda service told me medyo mahina na battery ko... haven't had the chance to personally test it (using a multi meter)
    Used to have one before, & had it for many years na rin, & was able to jump start multiple cars many times na. Should get a new one na again becasue the battery already bloated.
    Sep 2016
    #102
    I have one. Yoobao 150C. Saved me a couple of times already. Tested na gumagana yung jump starter nya. Napabilib din yung isang tinulungan ko noon nung di magstart ang sasakyan nya sa mall parking.
    Jul 2013
    #103
    I'm actually planning to get this one since my power bank is due for a replacement... might as well get one that can start my car/motorcycle (if required)
    TYLEX XP15 Car Igniter Powerbank 9600mAh 3.7V 2 Inputs & Dual Outputs 350A Start Current 700A Peak Current 12V Start Voltage
    Jan 2008
    #104
    Wouldn't be using any jump starter on modern cars with electronics ... just have 24 hours battery delivery in directory ...
    smarty smarty na po yung mga portable battery jump starters.. i think they're safe to use na.. some even detects if you place the clips incorrectly..
    usually the spark / spike in the initial clamping of the terminals that cause errors to the system.. that's why these portable jump starter need to be clamped first in the battery before you turn them on.. some have independent circuit for the jump starting that raises the voltage to the charging voltage of 14..
    Jan 2008
    #105
    watch mo yung video ni project farm testing those generic jump starter powerbanks vs expensive / branded ones.. yung ibang generic ang lakas.. talo pa yung expensive brands like NOCO..
    #106
    Are these jump starter powerbanks advisable to be left on the car in case of emergency? I was thinking of leaving one Sa lagayan ng spare tire. But I'm afraid if the car will be left in a hot sun the powerbank may start a fire.
    Jul 2013
    #107
    I'm planning to use it as my power bank... jump starter feature is just a bonus
    Sep 2016
    #108
    I don't leave mine in the car for that same reason. Dala ko sya lagi pagsakay at pagbaba.
    Mar 2004
    #109
    Or they drain away their charge by the time you need them ...
    Jan 2009
    #110
    I'm oldskool and just keep a pair of jumper cables in the car. And even that, in the last almost 8 years, haven't had a need to use it.
    Anyway, if you are looking for portable jump-start packs, choose one that has LiFePO4 (LFP) cells. Unlike Li-Po or Li-ion cells, LFP does not spontaneously combust. They're safe for storage in your car.
Jump Starter Power Bank
