Results 1 to 2 of 2
    May 2009
    Got a rainy day promo on my rear lamps since i've observed this problem comes out during the Ber months and now this rainy season.
    The problem is usually on the right rear lamp (or could be the left) since they share the same ground as per my stock knowledge. It stays on (mostly without my knowing) even the parking lamp switch is off. Tried pumping the brake pedal and the intensity doesn't increase. at the same time, left brake lamp does not also illuminate. Several pump on the brakes and it's gone to be back on some other night.....
    Brake lamps as well as parking lamps are ok most of the time....where could be that gremlin? brake switch or grounding points, or a load-to-load short?
    ayaw mo pumunta sa electrician bro? marami namang trusted na electrician dito. Kung malapit ka sa banawe, dun ka kay jemson.
Intermittent Rear Lamp Problem
