Originally Posted by
jick.cejoco
yes you are right in a way there is a dropping resistor in series with the glow plugs. i am looking at a 1985 mitsubishi truck 2.3 diesel. there are two power sources, one from relay glow plug relay l comes straight from the battery to terminal 30 to terminal 87 a on the relay to the 4 glow plugs direct. from glow plug relay 2, power to the dropping resistor then distributed to the parallel connected glow plugs comes from terminal 30. both glow plug relay 1 and 2 are activated by the glow control unit. relay 1 works as a fast glow if the coolant temperature is 86 degrees fahrenheit or lower, relay 2 with the dropping resistor works if the coolant temperature is above 86 degrees fahrenheit. from this control unit, a circuit controls the charge warning indicator, hence, the battery warning light malfunction. the common denominator for your symptoms is the glow control unit assuming your truck uses the same wiring as the u.s. version of the above mentioned truck
