Quote Originally Posted by gildred View Post
[SIZE=3]Vehicle: Starex GRX 2004 TCI[/SIZE]
[SIZE=3]Mileage: 137,000km[/SIZE]
[SIZE=3]Battery: Motolite Gold, 14 months old[/SIZE]
[SIZE=3]Alternator never opened and never encountered any problem before. [/SIZE]
[SIZE=3]Current Problem: Whenever the vehicle is not started for at least 2 days yung battery charge indicator lights up. While indicator light is on, voltage ay 12.3 to 12.5 lang. Hindi siya bumababa sa range na iyon kahit buksan pa ang air con. Pag pinatakbo na ng at least 5 kilometer, nawawala iyong ilaw at pag nawala na, nagiging 14.3 to 14.5v na ang voltage. [/SIZE]
[SIZE=3]Palaging ganun, pero lately, na observe ko, after mawala iyong ilaw hindi kaagad tumataas ang voltage. Tataas lang siya pag pinatakbo pa uli ng mas malayo. [/SIZE]
[SIZE=3]Nagpapalit na po ako ng alternator belt, na check at tama naman ang higpit nito.[/SIZE]
[SIZE=3]Normal po ba ito? I’m thinking, hindi ba IC na ito? Kung IC naman, bakit ok pa rin naman ang charging niya pag nagumpisa na siyang mag charge. Ano po sa tingin niyo?[/SIZE]
gildred,
sounds like your battery is going or yiour battery terminals have too much voltage drop at the terminals. before purchasing a new replacement battery, perform these tests:
1-check battery surface charge voltage in the morning before attempting to start the engine;
2-check the battery surface charge voltage after warming the engine up and shut engine down; compare the two(take notes)
3-perform voltage drop between the negative battery terminal by probing the battery post and the battery terminal clamp(positive test lead on the negative battery cable, the negative lead on the negative battery post(take note of voltage-should not exceed 0.3 volts) while cranking the engine over with the ECM or the EFI fuse to disable engine from starting and delivering fuel to the chambers;
4- perform similar test on between positive battery post and the positive battery cable clamp tester polarity reversed, the positive test probe on the cable clamp and the negative test probe on the positive battery post, voltage drop reading should not exceed 0.2 volts;
5-check battery voltage without any load- reading should be between 11.9 to 12.6 volts.
if voltage readings are below specs, replace with a known good battery and perform similar test
jick
