Results 11 to 20 of 24
- Nov 2007
- 14
April 4th, 2008 12:05 AM #11flakes, what have your idling prob resolved? was it by cleaning the throttle & IACV or was it by adjusting the throttle position sensor? have same prob kc! tnx!
April 4th, 2008 09:11 AM #12
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 9th, 2008 12:59 AM #13i suggest huli yung adjust ng tps since may tamang voltage dapat yun. most of the time people just screw it up and have bigger problems after adjusting it.
April 21st, 2008 11:15 AM #14
nangyari sakin ito ang ginawa ko linis lang ng TB hindi na ginalaw ang IAVC kasi sensitsitive daw grabi dumi kasi dahil sa air filter ung oil niya dumidikit sa TB ginamit carb cleaner or contact cleaner ung O2 sensor safe ngaun ok na
- Nov 2003
- 3,849
May 4th, 2008 05:02 PM #15the iacv isn't too sensitive naman as long as you use the correct cleaner to clean it.
December 6th, 2008 06:44 PM #16
up ko lang.nangyari naman ngayon sa kotse ko. 98 lxi. san makakabili nung cleaner saka anong brand maganda? plan ko kasi i-diy na lang kung madali naman since sunday bukas at malamang walang bukas na shop kasi "holiday"(laban ni pacman. wahahahaha). saka pano lilinisin un?
thanks.
December 6th, 2008 07:35 PM #17
ito ang mga naging guide ko bro: http://s3.zetaboards.com/HCP/topic/395106/1/ & http://s3.zetaboards.com/HCP/topic/397167/1/. silicone spray lang katapat niyan!
December 6th, 2008 08:55 PM #18
December 7th, 2008 12:18 AM #19
- Jan 2008
- 4,726
December 7th, 2008 12:38 AM #20talaga po mag kaka oil yan kasi 100% working yung PCV system kung barado pcv system baka mag pop-out yung oil dipstick at tumalsik ang oil due to high pressure.... normal yan sa mga medyo luma na kotse gas or diesel engine... may oil mist kasi na kasama yung blow-by gasses past piston rings kaya pag daan sa PCV eh mapupunta yung oil sa intake.. plus mo pa yung dirt na can pass thru the air filter.. pag nag mix yan ang magiging cause ng gunk
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
