Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    help naman po. yung kotse ng tito ko nagkaroon ng idling problem, taas baba ung menor. nagpagawa kasi ng power window saka hu. yung sa power window daw naglagay pa ng relay... ano problem don? pinatignan na sa ibang shop kaso hindi makita kasi hindi alam kung ano ginalaw. sa monday daw sasama nila ung taong nagaayos ng power window at hu para malaman kung ano-ano ginalaw.
    baka lang may makapag bigay ng idea...
    (palipat na lang kung mali ng sub-forum, hindi ko kasi sure kung san eh.. duda ko kasi electricals lang. hehe)
    clean the iacv and throttle body. baka madumi lang. pwede mo diy iyan para di ka na gumastos ng malaki.
    hth
    hth
    thanks, sige sabihin ko rin.. pero tingin ko kasi sa electricals since un lang ung huling nagalaw bago magloko.
    badtrip na badtrip ung tita ko kasi maayos na maayos ung kotse bago ipagawa.
    Aug 2006
    How do you clean the Throttle Body and IACV san located kasi same problem ako
    Oct 2007
    The Throttle Body, IACV and Intake Manifold is just on top of the head. Yung kinakabitan ng air filter mo. Yun na yon.
    *TS:
    If it's the electrical that you're doubting, then try installing a grounding kit. Also, ask the person who did the repair on the power window and the HU. Maybe he did something wrong with the wiring.
    Aug 2006
    happens to me before...try to have the TPS (Throtlle position sensor) adjust muna baka dun lang problema...
    hope that helps
    Aug 2006
    Thanks very much
    mga bros ok na yung kotse. tama nga kayo, throttle body lang. hehehe. napatyempo lang daw siguro nung nagpaayos. hehe.
    thanks
    Jan 2008
    Kitam! Pero ingat ka dapat O2 SENSOR safe yung cleaner na gamit mo, mahal ang damyos pag natigok yan.
    Nov 2003
    unless it is a 2000 up car it probably doesn't have o2 sensors pa.
    in most cases cleaning the iacv/tb will do the trick.
    Nov 2007
    flakes, what have your idling prob resolved? was it by cleaning the throttle & IACV or was it by adjusting the throttle position sensor? have same prob kc! tnx!
    Aug 2006
    Try to have your TPS adjust first and see kung may difference sa idling mo...pag the same padin..then its time to have your throttle body clean...
    HTH..
    Quote Originally Posted by heavenn75 View Post
    Nov 2003
    i suggest huli yung adjust ng tps since may tamang voltage dapat yun. most of the time people just screw it up and have bigger problems after adjusting it.
    Aug 2006
    nangyari sakin ito ang ginawa ko linis lang ng TB hindi na ginalaw ang IAVC kasi sensitsitive daw grabi dumi kasi dahil sa air filter ung oil niya dumidikit sa TB ginamit carb cleaner or contact cleaner ung O2 sensor safe ngaun ok na
    Nov 2003
    the iacv isn't too sensitive naman as long as you use the correct cleaner to clean it.
    up ko lang.nangyari naman ngayon sa kotse ko. 98 lxi. san makakabili nung cleaner saka anong brand maganda? plan ko kasi i-diy na lang kung madali naman since sunday bukas at malamang walang bukas na shop kasi "holiday"(laban ni pacman. wahahahaha). saka pano lilinisin un?
    thanks.
    ito ang mga naging guide ko bro: http://s3.zetaboards.com/HCP/topic/395106/1/ & http://s3.zetaboards.com/HCP/topic/397167/1/. silicone spray lang katapat niyan!
    Oct 2008
    Quote Originally Posted by Cobalt Blue View Post
    sir kaya nagka oil yun dahil sa pcv system po... barado na kaya nag backflow na yung oil sa air cleaner
    medyo mahirap pala. dalin ko na lang sa talyer. hehehe. salamat
    Jan 2008
    Quote Originally Posted by technismo View Post
    talaga po mag kaka oil yan kasi 100% working yung PCV system kung barado pcv system baka mag pop-out yung oil dipstick at tumalsik ang oil due to high pressure.... normal yan sa mga medyo luma na kotse gas or diesel engine... may oil mist kasi na kasama yung blow-by gasses past piston rings kaya pag daan sa PCV eh mapupunta yung oil sa intake.. plus mo pa yung dirt na can pass thru the air filter.. pag nag mix yan ang magiging cause ng gunk
idling problem 96 civic vti
