Page 33 of 38 FirstFirst ... 23293031323334353637 ... LastLast
Results 641 to 660 of 754
    it depends if the battery has charged up already
    #642
    Nag start but the electrical shop said I need to be there early. I will have my batt charged na lang and see if it lasts until next week
    Sent from my GT-N7100 using Tapatalk 4 Beta
    Ginawa ko negative to negative umandar naman. Ang galing naman ng Amaron battery
    see?
    neg to neg
    it works
    and no nuclear explosion
    #644
    I brought the battery to Motolite. They won't charge it anymore kasi 12.5 daw but when they turned the knob on the tester it drops to 7 daw. It means one of the whatever is dead na daw. Totoo ba yun? Naisip ko baka ayaw lang nila i charge kasi hindi Motolite yung battery ko. Yung 1SN Motolite gold costs 4.7k
    #645
    12.5 patay makina?
    neg to neg talaga dapat.
    #646
    Quote Originally Posted by [archie] View Post
    12.5 patay makina?
    Nakatanggal na yung battery nung dinala ko sa Motolite.
    #647
    baka patay na isang plate. In my opinion, just get the battery charged up enough to bring it to electrical shop. it would be more accurate. hindi ako naniniwala sa sinabi kasi ginamit sa altis at wala naman naging problem.
    baka talo sa charging.
    bili ka nalang ng cheap battery huwag motolite gold. pambenta lang naman eh
    kaya lang pag bumili ka ng battery tapos di mo naman gagamitin yung corolla madidiskarga lang yan
    #649
    motolite sells a low end maintenance-free brand. "Champion". you can get two champions for the price of one gold. warranty is 12 months.
    #650
    Yun ang sinabi. Patay daw ang isang plate. Eh bakit ning jinumper cable ko umandar. Pinatay ko tapos umandar ulit. Nakakataka nga kasi wala naman problema yung battery na yun sa Altis. Then one week after ko ikabit sa corolla biglang nasira?
    #651
    1. you can have the battery charged now. if you connect it next week and the car starts, then your battery is good. if it does not start, then your battery is in need of replacement. (this test determines your battery's ability to hold the charge.)
    2. if you are able to start the car as in #1 above, your probable headache-causing culprit is either a defective alternator or poor electrical connections, either of which can result in a weak battery. or, you have a parasite.
    3. testing for parasite is easy. all you need is an ammeter: with the engine off, key out, and all other appliances off (but not disconnected) disconnect the main cable to the battery, and connect the ammeter probes in between the battery and the cable, observing polarity. note the ammeter reading. it should be "very small" (less than 0.1 amp). of course, most car owners do not have an ammeter nor know how to use it. thus, bring the car to the fixit shop na lang. heh heh.
    4. #3 above is the easy part. the hard part is finding out where the leak is.. THIS is what separates the boys from the men.
    seriously, bring the car to the battery shop. a well-equipped shop can test the battery's condition and the alternator's condition. most will not charge diagnosis fees, because it is easy to do. they make their profit on battery you will most likely buy from them.
    now, testing for parasites... that takes a little more intelligence.
    btw, if your car is MT, try push-starting it to get it going. most efi cars with weak (not dead and buried!) battery will start easily this way. you need just two slaves to push.. and even dying batteries will start a newly-died engine if immediately re-started..
    good luck.
    Hi Sir. I followed your advise to have the battery charged then see if it holds up for a week to find out if the battery is the problem. But motolite does not want to charge it anymore. Hay! I am not sold on their explanation that the battery cannot be charged na
    #652
    with a voltage drop like that, i'll believe them that i need a new battery.
    even dying batteries can hold a charge sufficient large to enable you to re-start the engine if you do it "soon enough". but they can't hold onto that charge for a "long time" (as in, overnight).
    syangapala.. what did they say about the alternator? if the alternator's ok, then it most probably is the battery.
    coz you use the altis everyday
    sa corolla you leave it there
    #654
    Sorry, I was not able to have the battery charged at all because when I brought it to Motolite, they refused to charge it kasi when they put the clamps it was on the green zone (12.5) then when they twisted the knob on the tester it dropped to 7 daw.
    But the corolla gets started everyday pero it gets weaker as days pass then after a week, dead na. Pero when I used the jumper cable umandar naman. I turned it off after removing the cable then it started again.
    #655
    hija, ganito na lang:
    jumper it and start it.
    then use the car so the engine can charge the battery.
    when you get home, disconnect the battery.
    re-connect after 2 , 3, or 5 days. if the car doesn't start, it's time to get a new battery.
    #656
    Thank you I like this method!
    How long should i use the battery? Is 2 kms sufficient? I am afraid to drive it far kasi. It might not start bigla.
    #657
    its pretty hard to judge since nauubos kagad yung battery. I think namatay plate yung nadiskarga. pwede nagkataon lang na pabigay na yung sa altis battery or talo sa charging. best is to torture test the battery.
    let the corolla run for 30mins, go around your village or something without electrical load. let the car rest for 3 to 5 days. Start, kung mahina redondo, battery na. pero kung malakas redondo, talo sa charging. you mentioned na umilaw yung batt sign dati, baka nagloloko na ic ng alternator.
    #658
    isa pa option, bring it to uls. tapos problema.
    #659
    glad you like it!
    2 km is fine. just don't you use the aircon or the lights, so the alternator output goes only to the battery. and if the engine dies, start it right away. it'll start.
    we don't have to fully charge the battery. we are just testing the battery's ability to hold charge.
    #660
    Hindi naman pala umilaw yung battery sign Mommy ko kasi naduduling na ata. Yung sa door pala yung nakita niya. haaayyyyy.
    Ano ibig sabihin talo sa charging?
How to Know If It Is Only A Battery Problem
