Results 1 to 20 of 754
    Oct 2011
    Naku, baligtad pala negative and positive terminal ng 1SN sa 1SM. Have a qualified electrician to do it when replacing your battery cat, baka sumabog ito pag baligtad. Always remember roses are red (positive) black is negative.
    kung baligtad position ng terminal so baligtarin ang position ng battery para umabot mga terminal
    pag di umabot ang terminal doon na problemahin
    actually di pa nga alam ni cathy kung sira na talaga battery ng corolla
    baka nadiskarga lang sa tagal di ginamit ang sasakyan
    baka pwede na i-recharge yan
    baket kasi di tanggalin ang battery ng corolla at dalhin sa battery shop para ipa-check
    ang dami scenario naiisip ka-simple simple ng problema di maayos ayos
    AFAIK
    1SN is reverse polarity of 1SM or vice versa.
    1SM - Positve pole (red) is on the right hand side of the battery
    1SN - Positive pole (red) is on the left hand side of the battery
    You can use both batteries, provided that your battery cables are long enough to reach the correct poles. If not, then buy the correct battery for your corolla.
    And this is the reason why I am asking a lot of questions. Thanks LSB.
    Oo nga e!!! I might end up making my corolla's problem worse Bili na nga lang ako new battery for my corolla. Nakaka asar
    Sent from my GT-N7100 using Tapatalk 4 Beta
    hindi ka naman siguro ganyan katanga na ikakabit mo yung + sa -
    may kulay at symbol naman ang terminal
    kung nakita mo baligtad ang terminal di mo naman siguro ikakabit diba?
    hindi pa nga sigurado dami na iniisip
    baket di nalang hintayin umuwi sa bahay at buksan ang hood ng corolla para tingnan kung ano itsura ng battery
    Oct 2011
    Have you decided on which battery to buy? Amaron na lang....
    yan ang problema pag kausap mga "academic"
    you throw around theories about things but don't bother checking on the actual things
    you sit around debating kung pareho ang battery ng dalawang sasakyan but nobody bothers to go pop the hood of the cars to find out
    Mamaya nga. Kanina ko lang kasi naisip na yun Altis na lang bibilhan ko ng bago battery.
    dapat lang bilhan mo na ng bagong battery yung altis sabi mo nga 3 taon na yan. di mo lang ginagawa kasi ayaw mo mareset ang radyo
    huwag mo muna problemahin na di pwede sa corolla ang battery ng altis coz di mo pa nasilip yung corolla
    chances are pwede yung battery ng altis sa corolla kahit baligtad ang terminal pwede i-position ang battery para umabot ang terminal
    kung talaga di aabot then bilhan mo ng murang battery para maibenta lang yung corolla
    Sagot ka sa thread ko. Amaron or Panasonic.
How to Know If It Is Only A Battery Problem
