Results 1 to 6 of 6
August 12th, 2008 07:17 PM #1
The car is a 2004 Lancer MX (with SRS bags). Is there a cheaper way to repair the horn switch of the car without replacing the whole set? We asked the casa regarding the repair, and it amounted to around 8k. just for the repair/replacement of the horn switch by the steering wheel. Crazy. Reason: it has airbags, so they have to replace the airbags as well. The steering wheel horn switch works sometimes, most of the time it doesn't. I did install a separate switch for the horn, but that defeats the purpose of have a horn button ready by the steering wheel. Is there a way, or is there a shop who could take care of removing the airbags and replacing/repairing the horn switch (the casa not included of course)?Could the relay have a glitch perhaps? Would it be safe to just replace the relay without triggering the srs airbags?
THE AUTO SPECIALIST
- Mar 2006
- 607
August 12th, 2008 08:21 PM #2i think the casa is pointing to the clockspring not the airbag assembly itself.
the driver's airbag has to come out in order to replace the clockspring
ive seen lots of problems from the clockspring and not even one to the horn switch
August 14th, 2008 02:23 AM #3
so the clockspring plus labor costs around 10k? quite a steal...is it possible to replace the clockspring without triggering the airbags? on my own or through other shops with a much cheaper labor?
THE AUTO SPECIALIST
- Mar 2006
- 607
August 14th, 2008 06:17 AM #4replacing the clockspring ;
ignition off
remove neg . battery term.
press brake pedal 25 times
wait at least five minutes
then you can start to work on it
worst scenario airbag light sets after repairs
you have to know a shop that's equipped with scanner that can work on your car (erase the code)
August 16th, 2008 11:18 AM #5
mga tsikoteers! would anyone know a shop that's equipped with a scanner as bambino mentioned?
bambino thanks!
Tsikot Member Rank 5
- Nov 2003
- 3,848
August 31st, 2008 03:48 PM #6tama lang yung price na yan for the clockspring.the airbag and horn functions are both integrated in that one ribbon.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
