Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Oct 2007
    hehe, sorry may tanong po ulit ako mga sirs. ay sorry, mga tanong pala.. hehee
    how can i increase horsepower of a honda city type z 2002? where do i start? tska mga magkano kay budget dun? and san kaya may maganda shop kung sakasakali ? nagsstart pa lang kc ko abt cars, wala pa talaga masyado alam to be honest.
    thanks ins advance ulit...
    Quote Originally Posted by dirk0616 View Post
    usually ... you start with high tension wires and some good kinds or spark plugs ...
    k&n filters which will give you the added wind power ...
    and i guess i good motor oil synthetic or a duralube additive
    budget for this around 10k .....
    Oct 2007
    thanks po sir,
    since nasimulan ko na, hehe sasagarin ko na, may alam po ba kau na auto shop na hindi naman ako tatagain? and naghanap na rin ako ng k and n air filter, hirap maghanap para sa type z, tska mga ilang horsepower kaya madadagdag?
    thanks ulit ng madami...
    Jul 2006
    what type of filter are you referring? the Drop ins? if you don't have the money to burn, go for simota first, it's way cheaper.
    An upgrade of the headers will also add some hp to your engine.
    For shops, try going for shops in evangelista or banawe. There are lots of surplus or 2nd hand you might wanna try first.
    Oct 2007
    thanks for the input mga bossing... ill try sa banawe...
    rilly appreciate it..
    Jun 2007
    turbocharger!
    Oct 2007
    sir start ka muna sa oil, yun maganda then put an oil additve, dapat madulas yun oil mo para less ang friction to produce more horsepower. after nun -modify mo na engine mo.
    Aug 2004
    You don't need to add an additive... it's a needless expense. Buy a good synthetic oil and leave it as is.
    Synthetic oils already have additive blends mixed in... if you're adding another additive on top of that, the results can be a little unpredictable.
    And mineral + additive is still not as good as a good synthetic. Buy a synthetic with a good base stock, and leave it as is. A good synthetic will resist wear and breaking down over time than a poor oil bolstered with additives... additives will break down over time, anyway.
    You don't need high tension wires unless your old ones are already cracked or have high resistance. Unless you're making much more power than stock, OEM replacements (i.e.: Honda branded) will do.
    For the proper plugs for your ride, review Honda forums and see what the performance pros recommend for the D15. I'll bet they will all swear by the stock NGKs.
    As for airfilters, best combo is a Simota tube and a K&N cone filter. The K&N is expensive, but it's much better, and worth the money.
    But these are all "efficiency" mods... the sum total of which will probably only be about 5-6 hp. For more power, it's either turbo, engine swap or exhaust work. Exhaust work for the City should cost 30,000 or less, total, for a good exhaust. Turbo? Maybe 80,000. Engine swap? About 100,000 pesos will get you a Honda B16A engine with 170 hp... about the same as you would get with a turbo (or a little more) and it's more reliable.
    Set aside money for good performance tires and brake pads... you'll need them if you're going for power.
    Hey, speed isn't cheap.
    thanks po sir,
    call me at the store ... i can refer you to a k&n supplier pero got to warn you ... mahal yan ...
    if you like simota is a good replacements ... maraming taiwan around 500 - 700 + yung filter and pag kasama extension i think about 2000 - 3000 + more or less
    if you have money to burn try looking for ichiban motor parts ... this shop will try to hook you up if you wanna change engine ... pero not sure if has any honda engines ... usually toyota
    pero in banawe there are lots of shops try looking there na lang ...
    BANAWE AUTO SUPPLY
    7120115
    regy
    Oct 2007
    Simple... exhaust plus full cat tubing.... equals fifty to seventy horses and your engine will breathe better cause of more air coming in.. but more in fuel consuption
    speed is expensive
    Oct 2007
    thanks mga tol... appreciate it...
    honga lam ko mahal talaga k and n filters, i ll settle for simota muna. hehehe. low budget tau ngaun. but if im gonna go turbo, ano pb dapat i mod to make the turbo compatible with the system? sayang naman kc ung makina kung papalitan, bgo pa. hehehe. tska mas makakamura. cguro ngaun kht mga 30 - 40 hp increase ok muna. ung turbo sa xmas na, pag may bonus na! hahaha. gs2 ko nga rin sna ung catback system exhaust d ko lang alama magkano, tska kung compatible naman cya sa engine.
    hirap talaga ng walang alam...
    thanks ulit.
    Oct 2007
    hay..
    dko kaya turbo by xmas. matgala pa cguro yun. exhaust muna cguro. limited resources eh. hehe. for now ok na muna cguro ung 30-50 hp increase. cgro exhuast mod can reach the goal naman ata, synthetic oil, air intake...matagal tagal na ipunan to kung engine swap or turbo...
    thanks ulit
    Jun 2007
    ipa tune-up mo na rin, sir
    Oct 2007
    yes sir. actually sched na nya for tune upo this december, kakatune up lang nitong july.. hehe
    May 2007
    What kind of Horsepower are we talking here?
    A Horsepower gain from flywheel or Horsepower and Torque at the wheels.
    A horsepower from flywheel does not make any Horsepower, but it shows up a horsepower gain. Like vroom, vroom, vroom... changing your exhaust system not just the muffler(try magnaflow or Borla exhaust system)), much hotter plug, replaced your air filter into Typhoon cold air intake and so much more. This are the most economical way to gain power in your car.
    Horsepower and Torque at the wheels. Well, this is an expensive one and it depends how much horsepower you asking at. A good blown engine can cause you blood and sweat perhaps much more expensive than a brand new car if you really want speed. Avg price for modification, 20 up to 100 Grand(U.S dollar) for street legal. Non street legal it cost more. Stillen is accepting engine modification into any country except afghanistan.
    Quote Originally Posted by kenny357 View Post
    speed is expensive
    Exhaust mods wont give u 50-70hp increase.
    At most, intake and exhaust mods will only give u a 5-10hp increase.
    U can only get 50-70hp by forced induction. Turbo, supercharge, or N2O injection.
    hay..
    thanks ulit
    air filter, exhaust mods wont give u even close to 30-50hp increase.
    U can only get that if u force more air and fuel into the engine. Which can only happen with bigger injectors, compressors, blowers or a pressurized tank of laughing gas
    Oct 2007
    hay..
    thanks ulit
    sir try mo rin inquire yun nitro, pero swap engine di me favor dun, magastos yun at baka dami pa probelm ka ma encounter, unless new engine at di surplus ang kukunin mo.
    Sep 2006
    heheheh...dami di sigurado na mods...ang mamahal pa!
    ito sigurado...lighten your ride! if you can risk travelling without spare tire and tools at may pambayad ka sa tow service laki pagbabago yan. marami pa iba. bottom line is lighten your car.
    If it was that cheap and easy to make an additional 50 hp, every boy ricer out there would be driving around with 200 hp under the hood.
    But the reality is, it takes upwards of P100,000 for the average 1.6 liter japanese econocar to get 200 hp * wheels (with dyno numbers to prove it)
how do i increase horsepower?
