Results 1 to 9 of 9
February 19th, 2007 11:28 AM #1
Any emergency solution in case your power window breaks down and you cannot leave your car with a windows open and your alone ony?? ANy manual way to close the window?? Thanks..
WBR,
February 19th, 2007 11:42 AM #2
I have the same problem on my driver-side front window for my 2005 Honda City. Bloody thing goes up halfway then goes all the way down and just refuses to rise. :mad:
February 19th, 2007 12:19 PM #3
Happened to me before. In my case, ok pa ang motor ng Power Window pero sira ang mga switches. What the electrician did was connect to wires to the Battery (Positive and Neg). He then removed the door panel to expose the window motor tapos connected the wires to the motor casing (neg) and one wire running to the line connected to the switch. Ayun, sumara ang window.
February 19th, 2007 12:23 PM #4
If the motor can get it halfway up, then roll up your sleeves and use good old fashioned muscle power... try to pull it up the rest of the way while toggling the switch. Had to do this before on another car.
February 20th, 2007 12:59 AM #5
This has happened to me before, I drive all the way out somewhere to gimik, and sometimes my passeger side power window motor wire gets all jumbled up and it wont close completely, maybe a little bit more than halfway. Here's what i've done:
1. Swing the visor over to cover the window haha
2. Duct tape and carboard to cover up the window
The worst is when it rains! But, if you've got time to open up your door panel. Open it up...raise the window upward, use tape and pieces of carboard to wedge the window so it doesnt fall down. Then just have it fixed when you get home.
February 21st, 2007 12:35 AM #6
February 21st, 2007 12:52 AM #7
manually pull the window up and stick something in-between the window and the door sidings to prevent the window from going down.
February 21st, 2007 01:43 PM #8
check if there's something that jammed up the window by removing the door panel. otherwise, press up then alalay sa hila hehe
February 21st, 2007 03:07 PM #9
a car that i had sold more than ten years ago, to a bayan seller, is still apparently under my...
LTO car registration and late registration fees
