Results 1 to 15 of 15
    Sep 2010
    my horn sometimes does not function well... ngo ngo minsan, though most of the time its loud. what could be the cause? i know my battery is almost expired, can this be the cause? my electrician told me to buy a new horn because it is still the stock when we bought it, 1995 corolla to be exact
    Jan 2008
    replace or upgrade your horn and better install a separate relay..
    your horn is old. the electrical contacts inside are probably corroded and/or dirty. you can probably clean them IF you can open the horn, but the problem will be back in no time. some horns have an adjusting screw outside. you can try playing with it by turning it back and forth, to get the best sound. but the bottomline is, just replace the horn.
    btw, i notice this in toyotas. notice how soft many toyota taxis' horns are? my nissan doesn't have this problem, even after 14 years.
    Sep 2010
    so any suggestions on what horn could i possibly replace? possibly price too... i don't need a very expensive one though, as long as it is loud enough to be heard that would be fine for me... thanks guys
    Quote Originally Posted by batusai_jr View Post
    Stebel Nautilus
    loud.... very loud...
    Don't forget to add a relay.
    Stebel Nautilus
    nautilus FTW!
    Mitsuba Horns..
    Or.. Nathan K5LA
    [ame="http://www.youtube.com/watch?v=aNTl5AqKt58"]YouTube - 4th Of July Run By Special[/ame]
    http://www.hornblasters.com/products...5la-train-horn
    Sep 2010
    wow how much would that cost me? yan type ko pang bus o tren
    Jan 2009
    Holy moly, that is loud!!!
    Sep 2010
    it is loud, anyone has an idea where it is available? and how much?
    e-bay? Or kung masipag ka maghanap sa truck & firetruck supplies dami nyan. Problem monalang is compressor and 12v air-valve, usually kasi 24v ang available locally.(maybe ARB comp and switch for lockers would do - sa 4x4 shops)
    Check the notes na gusto mo then compare. Cheaper sa hornblaster yung package nila.
    [ame="http://www.youtube.com/watch?v=Qu80BBKzViE"]YouTube - Locomotive Horn Switch Panel Testing[/ame]
    Nathan: http://www.microprecisiongroup.com/nathan/kHorns.asp
    Kahlenberg: http://www.kahlenberg.com/commer.html
    Leslie's: http://www.lesliecontrols.com/Products/airwhistles.htm
    Feb 2005
    my 1990 ae92/4af stock horn is still working perfectly well
    Horny question ? :hysterical:
    Jun 2007
    ^^naintriga rin ako eh. akala ko kung ano yung thread
    hahaha takte sobrang lakas nung busina nung lancer :rofl:
    gusto ko ng ganito!
    Mar 2011
    i got the same horny problem on my 1995 civic. sometimes it works perfectly but oftentimes its "ngongo" or not working at all especially when i'm honking while turning the steering wheel. i think its the wiring(loose connection) that has the problem although i did'nt check that yet.
Horny question?
