This is a similar problem on my ESi. It turned out that the alternator rotor windings was found to have internal short, hence, charging was not at full capacity. I had the rotor replaced and car was back to normal.
A good electrical/alternator shop should have this test jig to verify the integrity of the rotor windings. Without a test jig, you'll need a known good rotor and perform coil resistance checks for comparison. Actually, before I accepted the new rotor, I insisted on the resistance checks, and true enough, an internal short was indicated on my old rotor.
When the engine is running, the battery voltage should nominally read 13.8 - 14.0 volts. Anything outside this range is a possible charging problem (including the battery).
Hope this helps.
