if i change ba my spark plugs does it follow that i have to change the wires too? how do i know if i need to change it na?
are they standard or specific fit per vehicle? i'd appreciate your recommendations![]()
it depends if you need to change your hi-tension wires. if your wires are already brittle and cracked, change them... also if some electrcity jumps out of the wires (sa gabi mo tignan, buksan mo hood, paandarin mo makina, pag may nakita kang kuryente na tumatalon galing sa wires, sira na yun) change them.
if you're planning to change them, go for the OEM. Mine is NGK (the blue one). im not sure with the sizes though, just bring your sample when you buy one.
hope this helps![]()
thanks aqua!
how do performance hi tension wires help, if ill stay with my oem ngk plugs?
The stock plug wires will do an OK job. Just make sure they're in good condition. Change them as well probably if your ride is around over 5 years old or so. I do think the stock, properly gapped, plugs will work well with the stock wires.
if my memory serves me right we had a 93 corolla gli a/t back then and when we used the high performance wires madaling nasisira yun spark plug na normal gusto nya yung mga platinum ba yun?..basta yung mahal..kaya binalik namin sa stock..i think masyadong malakas yung kuryente or something...
You can always do an inquiry on the phone and on-line.
https://hondaphil.com/contact-us
I'm presuming Honda Sta. Rosa na casa yan? You mentioned your car's a Civic.
Grabe naman sa gulang nun. They really want to strong arm you in to paying for labor & materials etc.
It's like some hospitals in here in the NCR that implement a "no medication sourced from outside the hospital" policy.
Its a precaution to avoid treatment with counterfeit drugs daw.
As far as I'm concerned, it should be the patient's choice.
Kung wala na warranty bumili ka na lang sa labas.
Sir ok ba ung ngk spark plug wires para sa 2000 civic?. May mabibilan na kasi ako nian dito samin.
Pero ngayon ko lang narinig yan na Hinde sila pwede magbenta ng spark plug pag hinde sila ang mag install it's like saying alisin na rin nila yun parts department nila since hinde sila pwede magbenta ng parts kung hinde sila ang mag install.
